Introducing Wyze Leak Sensor and Probe
Keep an eye out for leaks.
Place a Wyze Leak Sensor anywhere leaks are likely to happen, like underneath sinks, dishwashers, and in crawlspaces. The included Wyze Sensor Probe is designed to go where nothing else can to catch leaks, catching leaks in impossible-to-reach places.
Features we're excited about:
  • Place the sensor anywhere you need it with a sleek, slim design.
  • Get notified immediately of leaks in your home.
  • Up to 500 ft. of range from Wyze Sense Hub gives reliable connectivity even in basements or attics.
  • The included ultra-thin probe is designed to catch leaks in hard-to-reach places.
  • 18 months of battery life means you can have peace of mind without worrying about short-term battery drain.
Still need help?
