How big does a leak need to be to be detected?
Also, how wet does an area have to be?
For a water leak to be detected, both sensors on the bottom of the leak sensor must both sense moisture. The distance between the sensors is about 0.8 inches, and the height of the sensors from the ground is 0.5 mm.
Still need help?
