What is the IP rating for Wyze Leak Sensor and Probe?
Wyze Leak Sensor is IP67 Rated.
This means that it is 100% protected against solid objects like dust and sand, and it has been tested to work for at least 30 minutes while under 15 cm to 1 m of water.
Note: Wyze Leak Sensor and the included probe is not weatherproof and is for indoor-use only.
Still need help?
