Will the leak sensor work beyond the listed operating temperature?
Yes, but the accuracy may be off.
If you're using your leak sensor in really cold or really warm weather, the leak sensor's accuracy will be decreased. We do not recommend using the climate or leak sensors beyond the specified operating temperature: 32ºF-104ºF (0ºC-40ºC).
Still need help?
