My Wyze thermostat isn’t displaying the correct temperature.
Presents as: The thermostat is not displaying the correct temperature; it is warmer or cooler than the temperature displayed on the thermostat.
Troubleshooting:
    • Power Cycle your Wyze thermostat.
      • Turn the breaker off for about 30 seconds.
      • Check all your wiring to make sure everything is secure.
      • Turn the breaker back on.
    • Perform a factory reset and set the thermostat back up.
      • Press and hold the control wheel for 10 seconds.
    • If all else fails, please uninstall your Wyze thermostat and re-do the wiring.
  • Make sure to always turn the beaker off whenever handling the wiring.
Still need help?
