Can I use Wyze Scale S with my shoes on?
Yes, but it will only measure your weight.
If you step on the scale with socks and/or shoes on, Wyze Scale S will only be able to measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you must step on the scale with both feet while barefoot.
Still need help?
