The spotlight is flickering.
Problem
The spotlight is connected but continues to flicker.
Troubleshooting Tips:
  1. Check for a firmware update.
    • In the Wyze app, tap Account > Firmware Update.
    • If you see Update next to your camera, tap Update.
  2. Make sure the connections to the splitter are fully plugged in.
    • Disconnect, then reconnect the camera and spotlight's cables. Push them tightly to secure.
  3. Power cycle your Wyze Cam v3 with the spotlight connected.
    • Unplug the camera from power, wait 5-10 seconds, then plug it back in.
If the spotlight still isn't working correctly, please contact Support so one of our Wizards can help you find a resolution.
Still need help?
