The Wyze Light Strip (Pro) will not Power OFF.
Problem: You are unable to power the light strip off using the app or the remote.
Troubleshooting:
  • Update your Wyze app in the app store.
  • Make sure your Wyze Strip Firmware is up to date.
    • Navigate to the Account tab. Tap Firmware Update. If you see the option to update your Wyze Strip, go ahead with that step.
  • Force close your Wyze app.
  • Sign out of the app and sign back in.
  • Power cycle your Wyze Strip, by unplugging it and plugging it back in after about 30 seconds.
  • Perform a factory reset.
    • Before performing this step, please send us an app log and take note of the ID it generates for you. Doing the factory reset before sending a log can delete helpful information that could identify what is causing the issue.
      • In the Wyze app, tap on the Wyze Strip (pro).
      • Tap the settings icon.
      • Tap Wyze Support > Submit a log
      • Choose the Wyze Light Strip (pro) > Lighting Issues
    • To perform a factory reset, Press and hold the side button on the controller for 7+ seconds until the strip starts pulsing.
Still need help?
