How do I check the battery level?
You can check the battery % for Wyze Buds in the app.
  1. In the Wyze app, tap on your Wyze Buds.
  2. Tap the Settings gear.
  3. The battery levels are at the top of the screen.
Note: A “Low Battery” audio prompt will play when your buds reach 20%.
Was this article helpful?
0 out of 0 found this helpful
  • Live Support Hours:
