Introducing Wyze Switch
Control your Wyze devices with the press of a button.
Wyze Switch is our new smart switch that lets you control your regular bulbs, Wyze Bulbs, and nearly all your other smart things.
Note: This is a single-pole switch. Neutral wiring is required.
What we love about Wyze Switch:
  • Works with Regular and Smart Bulbs. Choose Classic Control for regular light fixtures, or Smart Control for multiple smart devices.
  • Control Your Smart Devices With the Press of a Button. Group your devices by zones or floors for greater and more efficient control with your Wyze Switch.
  • Keep Your Settings, Even When the Power’s Out. Unlike other smart switches, Wyze Switch keeps all your settings the same even if it loses power.
  • Set Timers and Schedules in the Wyze App. Schedule lights or use timers to turn your lighting on/off at specific times.
  • Vacation Mode for When You’re Away. Wyze Switch can make it look like you’re home even when you’re not.
  • Works with Alexa and Google Assistant. Turn your switch on or off with your voice using Alexa or Google Assistant.
Still need help?
