Can I use Wyze Cam Pan v2 outdoors?
No, it is for indoor use only.
Wyze Cam Pan is not IP rated, and has not been designed for outdoor use. It will not be covered by our warranty if used outdoors. The lens, speaker, and charging ports are not weatherproof, and the camera should not be mounted or left outdoors for an extended period of time.
Looking for an outdoor camera? Check out Wyze Cam v3 or Wyze Cam Outdoor on wyze.com!
Still need help?
