Problem:
There is a static, crackling noise when viewing / listening to the live stream.
Troubleshooting Tips:
- Check that your Wyze app and firmware are up to date.
- Learn how: How to keep your Wyze Cams up to date
- Power cycle the camera by unplugging it from power, then plugging it back in.
- Try to factory reset your camera.
- Try to flash the firmware to an earlier version if you have a 32 GB microSD card available.
- Learn how: Flash Firmware.
If you continue to have issues with static in the live stream, reach out to our Wyze Wizards for more help.
