Introducing Wyze Video Doorbell Pro
See more than ever before, with no hidden fees.
Wyze Video Doorbell Pro is our wire-free, screw-free, hassle-free doorbell that can be mounted anywhere in seconds.
Note: Wyze Video Doorbell is a wireless doorbell with the option to hardwire it to your existing setup. You do not need a wired doorbell to use Wyze Video Doorbell Pro.
Wyze Video Doorbell Pro Features:
30-Second, Wire-Free Installation. Install it anywhere, quickly and with no wiring required.
…But You Can Hardwire It if You Want. Can be installed wire-free, or wired, which can provide up to an additional 6 seconds of recording length.
1:1 Aspect Ratio & 1440p Full HD Video. With a 150º horizontal, 150º vertical field of view, and a 1:1 aspect ratio, you’ll see everything in front of your door.
Up to 6 Months of Battery Life. Wyze Video Doorbell Pro lasts up to 180 days on a single charge.
Dual-Band Wi-Fi Connectivity 2.4 GHz/5 GHz. Connect to either your 2.4 GHz or 5 GHz Wi-Fi network.
Instant Notifications. Never miss another visitor, unless you want to.
Motion Detection, Smart Alerts & Video Recording. Wyze Video Doorbell Pro lights up brightly when motion is detected nearby, alerting visitors and would-be porch pirates of your video doorbell.
IP65 Weather-Resistant. Built to endure the elements.
Cam Plus Compatible. Optional upgrade available.
Upgrade to Cam Plus for $2.99/month to receive real-time alerts when people or packages are detected, and store full-length videos in the cloud.
Wyze Chime Pro Included. Hear your doorbell ring, chirp, or bark from any room.
Still need help?
