How to reset Wyze Video Doorbell Pro?
A factory reset deletes the settings file on the camera and rolls it back to the default settings. It can also be performed as a troubleshooting step for restoring a device to a previous working status if issues arise.
To factory reset your doorbell and chime:
  1. Press and hold the button on the side of Wyze Chime Pro for 3-5 seconds until it says "Reset successfully".
  2. The WiFi signal LED will start flashing red > solid yellow > flashing yellow.
  3. The device is now ready to be set up again.
Please note: If you're troubleshooting issues with your doorbell or chime, be sure to Submit a Log before performing a factory reset.
