Can I use Wyze Bulb White with a dimmer switch?
No, Wyze Bulb should not be on a dimmer.
Wyze Bulb White (and Color) should only be dimmed from the Wyze app or via a voice assistant.
We do not recommend installing Wyze Bulbs on a dimmer switch. If you must, make sure the switch is at full power at all times.
Still need help?
