My floor lamp isn't recognizing Daylight Saving Time.
Problem
After Daylight Saving Time, your Schedules haven't updated to the hour change. Your Wyze Floor Lamp is still turning on/ off an hour too early or too late.
Troubleshooting Tip:
Sync your Wyze Floor Lamp with the Wyze app.
  • In the Wyze app, tap on your Wyze Floor Lamp. Once the page loads, your phone's current time and the bulb will sync automatically. Then you're all set!
Still need help?
