Wyze Switch isn't following the Timer settings.
Problem:
Your Wyze Switch is not adhering to the timer you set.
Troubleshooting Tips:
  • Make sure your Wyze app is up-to-date.
    • In the Wyze app, navigate to the Account tab > tap About.
    • Your current app version will be listed under the Wyze logo.
    • Please compare your current installed version to the most up to date version on our Release Notes & Firmware page.
    • If your Wyze app is not updated to the latest firmware, head over to your app store, search for the Wyze app, and tap Update
  • Make sure your Wyze Switch firmware is up to date.
    • In the Wyze app, navigate to the Account tab > tap Firmware Update.
    • On this page, locate your Wyze Switch. If you have the option to update the switch firmware, please proceed with the update.
  • Delete the timer rule and recreate it.
  • Power cycle your Wyze Switch by flipping the breaker for the switch OFF for 30 seconds, then flipping it back ON.
  • Reboot your WiFi router.
Was this article helpful?
0 out of 0 found this helpful
