What happens if I am not home and alarm is triggered?
This is what Cam Plus Pro is for.
Cam Plus Pro is designed for exactly this - a person is detected by your camera and you're not home.
If you are not home and an alarm is triggered, you will be alerted via notification, SMS text, and a phone call from Noonlight. If you're on iOS and have enabled Critical Alerts, you'll get that alert as well.
You'll be able to check the alert and cancel the alarm remotely from the Wyze app using your PIN or with a security monitoring agent. If it is truly an alarm, you'll coordinate with Noonlight to send the proper authorities to your home.
