Wyze Bulb Color can be added to light strip groups in the Wyze app.
To create a Wyze Light Strip Group:
- Click the plus sign at the top left corner of the home page,
- Tap Add Device Group > Light Strip Group.
- Add a name to the group, then add a checkmark next to each light strip you want to add to the group.
- Tap Done.
- Tap on your group from the Home screen.
- Tap the Settings gear > Lights in Group, then tap the + plus sign next to the bulb(s) you want to add to the group.
- Tap Done. Your changes will be saved automatically.
Additional Note:
A Wyze Bulb can be added to an existing Wyze Light Strip group. But at this time, Wyze Light Strips cannot be added to an existing Wyze Bulb groups.
