Grouping your Wyze Light Strip (and Pro)
Grouping
Like many other Wyze products, you are able to group you Light Strip and Light Strip Pros together for easier control. However, Wyze Light Strip Groups even allow you to add Wyze Bulb White and Wyze Bulb Color making it easy to control all the lighting devices in your room at once.
Creating a group
To create a group:
  1. In the Wyze app, tap on the ‘+' sign on the top left corner of the home tab.
  2. Tap Add Device Group > Light Strip Group.
  3. Select the light strip(s) you’d like in the group.
Once the group has been created you can add additional devices (including Wyze Bulb White and Wyze Bulb Color) by going to the group setting page and tapping ‘Lights in Group’. One thing to note is that products can only be in one group, so if you already have bulbs grouped together, you should remove that group before adding them into the new light strip group.
Controlling a group
Grouped devices can be controlled together or independently. By default, when you go into a group page you’ll see all your products as small circles along the top of the screen. If you adjust any parameters (e.g. color, brightness, power state) you’ll notice that all your devices will change. If you’d like to only control a few devices at a time you can simply tap on their icon which will add a blue checkmark. You can now adjust the parameter of that product individually.
Still need help?
