Wyze Swich Compatibility Check
  1. Single Pole: If your lights can only be controlled from a single light switch, then it is a single pole switch and is compatible with Wyze Switch.
  2. Neutral Wiring: If your house was built after 1980, then you should have neutral wiring. If built before 1980, then you need to check your wiring. Need more information?
Additional Note:
For more details about Wyze Switch compatibility, check out: Is my wiring compatible with Wyze Switch?
