Yes, using the included mounting screws.
Wyze Gun Safe can be mounted for storage using the included mounting screws. Find the two pre-drilled holes inside the safe, and use the screws to mount the safe to a flat surface.
To mount Wyze Gun Safe:
- Check your mounting location and make sure:
- The mounting surface is flat.
- There is enough clearance for the lid to fully open.
- Position the safe at your mounting location.
- Find the pre-drilled holes on the bottom of the safe and use a pencil to mark the holes for drilling.
- Drill plot holes.
- Position the safe in place and install the mounting screws through the safe and into the plot holes.
- Tighten the screws to complete installation.
