The activation code is on the box.
Here are some steps that will help you set up your system:
- If your kit contains a sticker on the outside of the box with an Activation Code, here are the steps to follow:
1. Please log in to Services Website
2. Click on Have a code on the top right corner of the page.
3. Enter the activation code on the box and click Apply.
- If your kit does not have a sticker outside the box, please follow these steps:
- Download the Wyze App from the IOS store/ Google Play store
- Unbox your Wyze Sense Hub and plug in the power cable.
- Open the Wyze app, go to the Monitoring tab, click “Set Up System”,
then follow the instructions to add the Sense Hub. When prompted,
click “Activate” to activate your service. - After activating your service, follow the remaining instructions to
finish the setup.
Please note:
If you didn’t see the Activation screen, or the activation failed, please have
your receipt, the package, and the MAC address* ready, then contact
Wyze customer service: https://support.wyze.com/hc/en-us
* The MAC address is located on the back of the Sense Hub
