What if I have a microSD card without Cam Plus Lite?
You can still keep your recordings.
Even without a Cam Plus subscription (including Cam Plus Lite), you can use a microSD card in your Wyze Cam to record Event videos. You can even turn on Continuous Recording in your camera's Settings.
When Continuous Recording is selected, the camera will continuously record video to your microSD card. When the card is full, the oldest footage will be overwritten.
The Continuous Recording feature will continue for Wyze Cam v2/v3, Wyze Cam Pan v1/v2 even if you don't have Cam Plus as the recordings will be stored locally on the microSD card instead of the cloud.
To turn on Continuous Recording:
  1. In the Wyze app, tap on your camera to view the live stream.
  2. Tap Settings > Advanced Settings > Local Storage > Local Recording to microSD card
  3. Select Continuous Recording.
To view your recordings, tap to view your camera's live stream, then tap View Playback.
Was this article helpful?
1 out of 1 found this helpful
  • Live Support Hours:
