How long do the purifier filters last?
It can vary depending on your environment and usage.
Wyze Air Filter life and performance varies depending on usage and your home environment. In general, we recommend replacing your air purifier filter at least every 6 months to maintain the best performance. If set up in the Wyze app, it will let you know when it is time to replace the filter.
Still need help?
