Put it in your most-used room.
With one air purifier, the ideal place to put it is in the room where you spend the most time each day. For most people this is the bedroom or living room.
Try to keep your device at least 1 foot away from walls or furniture to avoid blocking the air entrance and exit vents. This allows air to circulate properly and the air purifier to operate more efficiently. For the best purification effect, we recommend closing doors and windows.
