Problem:
The air purifier does not turn on or the screen does not light up when the air purifier is plugged into power.
Troubleshooting Tips:
- Check that the power cord is fully plugged in and that there is no visible damage.
- Power cycle your Wyze Air Purifier.
- Unplug your air purifier from its power source and plug it back in.
Factory reset the air purifier.
Press and hold the power button for 10 seconds.
- Plug your air purifier into another power source.
