If the change filter icon is lit after you've changed the filter, follow the steps below to reset it.
To reset the purifier's filter indicator:
Press and hold the Power button and Auto Mode button until the air purifier beeps and the Filter Replacement Indicator starts flashing. The Filter Replacement Indicator will stop flashing to indicate that it has been reset.
