What does Wyze Air Purifier come with?
A filter, a short manual, and an even shorter manual.
Wyze Air Purifier comes with the following in the box:
  • Wyze Air Purifier
  • Filter* (Pre-installed. You must remove the plastic packaging from the filter before first use.)
  • Quick Start Guide
  • Quick Guide for First Use
* When ordering Wyze Air Purifier, you can select the filter you want with it. You can choose from Allergen (Standard), Formaldehyde (Premium), and Wildfire (Special Use).
Still need help?
