Introducing Wyze Lock Bolt
Access at your fingertips.
Gone are the days of fumbling for your keys. Enter your home quickly and securely with just a tap.
Why we love Wyze Lock Bolt:
  • Fingerprint Unlock. Unlock your door in under a second! No digging around for keys, just set your fingerprint up in the app and you're good to go.
  • Numbered Keypad (+ Anti-Peep). Use an access code to get in, and even create unique codes for everyone. With Anti-Peep, you add extra numbers before and after the code and still unlock.
  • 20-Minute Installation. Wyze Lock Bolt installs on most US doors in about 20 minutes.
  • Auto-Lock. When the door closes, the lock auto-locks after a set amount of time.
  • Know Who Came Home. View the full access history of your Wyze Lock Bolt, including how it was locked/unlocked, who did it, and when.
  • Emergency USB-C Charging. If you forget to replace the batteries, do an brief charge to enter your access code.
  • Pick Proof and Waterproof. Wyze Lock Bolt is pickproof (there's no lock!) and IPX5 rated so it can withstand all weather conditions.
  • One Touch Lock. Locking the door is as simple as pressing one button.
Still need help?
