What if Bluetooth is disconnected?
Wyze Lock Bolt will still remember you.
Even when Bluetooth is disconnected, which will happen whenever you leave Bluetooth range, the lock will remember your fingerprints and access codes. You won't be locked out, you just won't be able to use the app again until you reconnect.
Still need help?
