How does the access history work?
It updates whenever you're in Bluetooth range.
When you enter the app and you are within Bluetooth range, Wyze Lock Bolt will update your history log to show past events that occurred since your last connection.
You can see who locked or unlocked your Wyze Lock Bolt, when they did so, and which method they used (app, fingerprint, code). You can also see records of the door jamming and 5 consecutive failed access attempts.
Still need help?
