My Wyze Lock Bolt's latch won't turn by hand.
Problem
You're trying to turn the lock's thumb latch, but it doesn't move. You feel resistance or it feels stuck.
Troubleshooting Tips:
  • If your Wyze Lock Bolt is already paired and set up in the app:
  • If the lock has not been paired and set up in the app:
    • Check your installation to make sure the door frame and deadbolt latch are aligned properly.
    • You may also have a door jam.
Still need help?
