- Make sure you are within Bluetooth-range of the Wyze Lock Bolt.
- Try going back to the Wyze app home page, then re-enter the Wyze Lock Bolt page and wait for 1-2 minutes.
- Sometimes, the history takes a few minutes to update and may take a few tries if the connection is slow.
- You can also clear any other apps or devices using Bluetooth if you have a lot of Bluetooth devices connected.
