Yes, there is Test Mode.
Cam Plus Pro has a Test Mode, which allows you to set up and try your settings without triggering a real alarm. You can enter Test Mode in your Cam Plus Pro Settings.
Note: When your system is in Test Mode emergency services will not be dispatched if an alarm is triggered.
