How do I set the scale to only measure my weight?
Wyze Scale X has a unique feature that lets you disable additional "smart" measurements and only measure your weight. By enabling this setting, the small electric current that's used for Body Impedance Analysis (BIA) is turned off.
To only measure your weight:
  1. In the Wyze app, tap on your Wyze Scale X.
  2. Tap on the gear to open your Scale Settings.
  3. Tap Users and select your Nickname.
  4. Tap the toggle next to Pregnancy/Weight-Only Mode, then Yes to confirm.
Still need help?
