My Wyze Scale X is not turning on.
Problem
The display doesn't turn on when you step on your Wyze Scale X.
Troubleshooting
  1. Double-check the battery compartment.
    1. Was the plastic strip completely removed during setup?
    2. Are 4 x 1.5V AAA batteries installed?
  2. Check the Wyze app for the battery level.
    • If low, replace the batteries.
If your scale doesn't turn on with new batteries, reach out to our Wizards team for more help.
Still need help?
