Here's everything you need to know about the latest Cam Protect feature: Smart Schedules.
Match your daily routine to arm and disarm your Wyze Cam automatically with this scheduling feature. This means you won't have to manually change your settings every time you're away from home.
To set up a Smart Schedule:
- In the Wyze app, tap on the Monitoring tab.
- Tap on the Settings icon.
- Tap Rules.
- Create a Schedule:
- Tap Mode and Time.
- Select a mode (Disarmed or Armed).
- Choose the time you'd like your system to enter that mode.
- Tap Save
- Select which days you want the schedule active
- Tap Save.
Example Schedule
To create a schedule to arm your Wyze Cam after you leave for work at 8:00 AM, and disarm when you get home at 5:30 PM, Monday through Friday.
- From your Cam Protect Settings, tap Rules.
- Tap the Armed tab.
- Select the time, 8:00 AM.
- Tap Save.
- Tap the Disarmed tab.
- Select the time, 5:30 PM.
- Tap Save.
- Under Repeats, tap to make sure Monday-Friday are selected in green.
- Tap Save.
