Does Wyze Mesh Router support wired backhaul?
Yes, it can optimize the backhaul path even if wired or over Wi-Fi.
Thanks to Wyze Intelligent Mesh, the mesh router automatically optimizes the backhaul path regardless of if it's a wired or Wi-Fi connection.
To set up a wired backhaul:
  1. Place your mesh routers next to each other and complete setup in the Wyze app.
    • This process can only be done via Wi-Fi and Bluetooth technology.
  2. After the routers are set up and operational, move them to the locations where you want them to be connected to the Ethernet backhaul.
    • All root and satellite routers must be wired to the same Ethernet backhaul for this feature to work.
  3. After the routers are connected to the same backhaul network, use the Wyze app to confirm that the routers are properly connected.
Still need help?
