To delete the root Wyze Mesh Router:
- In the Wyze app, on the Home tab, tap on the pencil icon.
- Tap Edit Device.
- Tap on the red delete icon next to the mesh router, then Done.
Note: Deleting the root mesh router will also delete all satellite routers paired to the root router.
To delete a satellite Wyze Mesh Router:
In the Wyze app, tap on your Wyze Mesh Router, then tap on the satellite router you want to delete. On that router's network home page, tap Remove Router.
