Release Notes & Firmware
Looking for the Wyze Cam v2 and Wyze Cam Pan webcam firmware? Download it here.
Android App
2026
Android App 2026
3.23.2.1001 (October 13, 2026)
  • Bug fixes
3.23.1.994 (October 5, 2026)
  • Fixed an issue that was preventing users from using the Thermostat (Android Only)
  • Bug fixes
3.23.0.989 (September 30, 2026)
  • Fixed an issue on Android where double-click sounds would trigger incorrectly on the event list (Android Only)
  • Bug fixes
3.22.1.979 (September 21, 2026)
  • Fixed an issue that prevented Android 17 users from using Wyze Thermostat.
  • Fixed an issue in the Friendly Faces registration flow that prevented Android users from seeing the correct registration button.
3.22.0.973 (September 16, 2026)
  • Improved in-app pop-up messages for low microSD card storage and microSD card errors.
  • Improved Motion Tagging behavior when Pan Scan and Tracking are enabled at the same time.
  • Fixed an issue where the Wi-Fi signal strength was displayed incorrectly during setup.
  • Fixed an issue where microSD card recordings could not be played back.
  • Fixed an issue where enabling the IR lights while the device was turned off did not take effect after the device was turned back on.
3.21.1.962 (September 3, 2026)
  • Fixed unresponsive device groups & devices on the Favorites page.
  • Fixed the price display issue on the service home page.
  • Fixed display and rendering issues with the Wyze Stories pop-up.
3.21.0.955 (August 31, 2026)
  • Added support for category-based and fuzzy keyword searches during the "Add Device" process.
  • Bug fixes.
3.20.0.941 (August 24, 2026)
  • Updates to the 60-day cloud storage experience.
  • Bug fixes.
3.19.0.935 (August 11, 2026)
  • Bug fixes.
3.18.0.918 (July 23, 2026)
  • Bug fixes.
3.17.0.904 (July 14, 2026)
  • Introduced guest shopping to allow users to browse products, build a cart, and complete checkouts without requiring an upfront login or signup
  • Bug fixes.
3.16.0.890 (June 25, 2026)
  • Added ability to convert existing “I’m Home/I’m Away” shortcuts into new location-triggered automations.
  • Added a "Camera in Privacy Mode" status display on the Favorites Page for supported PTZ cameras.
  • Added dark mode support for some dialogs.
  • Bug fixes.
3.15.0.876 (June 16, 2026)
  • Shared users can now independently manage their notification settings and use the Snooze button. Rollout covers Wyze Cam v3/v3 Pro, Wyze Cam v4, Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Battery Video Doorbell, Wyze Solar Cam Pan, Wyze Bulb Cam, and Wyze Floodlight v2.
  • Bug fixes
3.14.0.807 (May 27, 2026)
  • Bug fixes
3.13.0.784 (May 4, 2026)
  • Added support for Android 1x1 single device widget
  • Bug fixes
3.12.0.773 (April 23, 2026)
  • Improved device setup and onboarding reliability
  • More helpful prompts for location-based Automations
  • Added support for Wyze Mesh Router deletion
  • More reliable schedule experience for Wyze Plug on Android
  • Bug fixes
3.11.6.765 (April 6, 2026)
  • Bug fixes.
3.11.5.764 (March 31, 2026)
  • Bug fixes.
3.11.0.758 (March 23, 2026)
  • Device widgets now support on/off controls.
  • Optimized the user experience of snooze notifications.
  • Bug fixes.
3.10.6.753 (February 24, 2026)
  • Bug fixes.
3.10.5.749 (January 30, 2026)
  • Fixed an issue where shared users were unable to use the garage controller.
  • Bug fixes.
3.10.0.745 (January 22, 2026)
  • Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 now support "Turn on floodlight for" action in Automation
  • Bug fixes.
2025
Android App 2025
3.9.0.739 (December 15, 2025)
  • Expanded Friendly Faces triggered automation to all compatible cameras
  • Bug fixes.
3.8.7.725 (November 19, 2025)
  • Bug fixes
3.8.6.723 (November 7, 2025)
  • Bug fixes
3.8.5.722 (November 3, 2025)
  • Optimized the Event tab for Cam Unlimited Pro users
  • Bug fixes
3.8.1.718 (October 20, 2025)
  • Bug fixes
3.8.0.715 (October 16, 2025)
  • Added support for setting up Wyze Lamp Socket v2 using Wyze Cam Pan v4
  • Updated the doorbell camera settings page
  • Use Friendly Faces to automate your home with Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Cam v3 Pro, and more
  • Bug fixes
3.7.8.702 (September 17, 2025)
  • Fixed an issue that prevented setting time-lapse on some cameras
3.7.6.699 (September 8, 2025)
  • Bug fixes
3.7.5.697 (September 2, 2025)
  • Bug fixes
3.7.0.695 (August 27, 2025)
  • Passkey login now pops up at launch.
  • Bug fixes
3.6.6.683 (July 24, 2025)
  • Bug fixes.
3.6.5.682 (July 17, 2025)
  • Preview events instantly as you scrub through the timeline on the My Day page.
  • Bug fixes.
3.6.0.676 (July 8, 2025)
  • Optimizations and bug fixes
3.5.5.669 (May 29, 2025)
  • Bird Detection for Battery Cam Pro: Now enabled — perfect for use with your Bird Feeder!
  • Shared Cameras on Monitoring Tab: View shared cameras directly on the Multi-Cam Timeline.
  • Faster Event Navigation: Quickly jump to events with the new quick navigation button on the Multi-Cam Timeline.
3.5.1.666 (May 23, 2025)
  • Bug fixes
3.5.0.664 (May 15, 2025)
  • Added support for subcategories when setting up the device
  • Added support for setting detection zone in landscape mode on Wyze Cam OG
  • Added support for sharing event videos to TikTok, Facebook & Instagram
  • Added support for Dark Mode on the Monitoring Tab
  • Added support for horizontal timeline view on selected cameras (Wyze Battery Cam Pro, Floodlight Pro, Wyze Cam v4, v3 Pro, Floodlight v2, and Doorbell v2)
  • Bug fixes
3.4.5.650 (April 16, 2025)
  • MultiCam Timeline view will now stay awake
  • Resubscribe can now be directly accessed within the app
  • Enhanced the Smart Modes information page
3.4.0.640 (March 26, 2025)
  • Added support for Emergency Dispatch Button on the Home Page
  • Added up to 60-days of cloud storage for each of your cameras in the Event tab
  • Added support for new 'Curated' settings option in descriptive alerts page
  • Optimized the Beta firmware testing experience in the Beta Program
  • Bug fixes
3.3.6.626 (February 25, 2025)
  • Fixed an issue that caused a failure when submitting a log
3.3.5.623 (February 20, 2025)
  • Added support for biometric login
  • Moved microSD card settings to parent setting page
  • Improved usability for My Day page
  • Bug fixes
3.3.0.609 (January 13, 2025)
  • Added support for Cam Unlimited Pro
  • Added support for Descriptive Alert
  • Added support for landscape view in the Monitoring tab
  • Bug fixes
2024
Android App 2024
3.2.7.595 (November 26, 2024)
  • Fixed an issue where Wyze Battery Cam Pro crashed when clicking on the microSD card in the event playback page
3.2.6.592 (November 19, 2024)
  • Fixed an issue that caused the app to crash
  • Fixed an issue that affected Advanced Settings on some camera models
3.2.5.591 (November 14, 2024)
  • Introduced Multi-Page View for Monitoring Tab (up to 16 cameras with 4 pages).
  • Enhanced event insights in the Events tab allow you to review events across multiple cameras within seconds, all in one view.
  • Enabled automated modes based on a personalized schedule via Settings on Monitoring Tab.
  • Improved in-app purchase experience during onboarding.
3.2.2.586 (November 8, 2024)
  • Fixed an issue that caused data to fail to sync with Apple Health when Bluetooth is disabled
  • Changed the range color for some of the body metrics on scales
3.2.1.581 (October 28, 2024)
  • Bug fixes
3.2.0.580 (October 22, 2024)
  • Added the ability to toggle the Autoplay Video Live Stream for cameras on the Home tab via the App Settings on the Account tab.
  • Added support for two Camera Card Styles, Comfortable and Condensed, available in the App Settings on the Account tab.
  • Bug fixes
3.1.5.569 (September 23, 2024)
  • Optimized Friendly Face feature
  • Bug fixes
3.1.0.564 (September 9, 2024)
  • Added Smart Focus support for Wyze Cam v4 microSD card playback
  • Optimized Smart Focus for Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, and Wyze Cam Floodlight v2
  • Optimized battery icon for battery powered cameras
  • Optimized the camera connection performance of the favorite page
  • Bug fixes
3.0.5.558 (August 21, 2024)
  • The new Event Filters design provides easier access to Premium Filters
  • Bug fixes
3.0.0.519 (July 24, 2024)
  • Introducing the new Wyze app Home page
  • Support Split View in landscape mode for Wyze Cam V3 Pro, Wyze Battery Cam Pro, and Wyze Floodlight Pro
  • Optimization of My Day filter
  • Bug fixes
Note: This app is being gradually released. If you do not see it now, you should see it over the next few weeks.
2.50.9.512 (July 16, 2024)
  • Enhanced analytics with additional events
  • Introduced a reminder for subscription expiration in the monitoring tab
  • Improved the value proposition of Cam Unlimited in-app purchases
  • Fixed bugs related to subscription upsell
2.50.7.487 (June 6, 2024)
  • Optimized IAP flow
2.50.6.469 (May 28, 2024)
  • Fixed a bug caused by enabling the Friendly Face feature from a list
  • Implemented an update reminder system within the Monitoring tab
  • Enhanced the upgrade path by optimizing the service page
2.50.5.449 (April 25, 2024)
  • Enhancement of the Monitoring tab, featuring the activation of a multi-camera timeline for advanced monitoring users, coupled with an upgraded timeline scrubbing experience
  • Fixed an issue that prevented users from activating Wyze Sprinkler Plus service
2.50.2.442 (April 5, 2024)
  • Fixed a bug that caused crashes when viewing cameras on the Monitoring tab
2.50.1.441 (April 2, 2024)
  • Improvements and bug fixes
2.50.0.437 (March 25, 2024)
  • Added support for Wyze app login using Facebook and Amazon
  • Added support for snoozing Event Video notifications from a notification
  • Updated the Friendly Faces feature with a better face management and notification experience
  • Bug fixes
2.49.4.402 (February 14, 2024)
  • Updated version number
2.49.3.399 (February 13, 2024)
  • Optimized the in-app purchase flow
2.49.2.392 (February 7, 2024)
  • Added a manual AP Wi-Fi pairing method on the Pairing Failed page as a backup
  • Fixed the loading issue on the Detection Settings page
2.49.1.390 (February 1, 2024)
  • Bug fixes
2.49.0.386 (January 25, 2024)
  • Added support for the microphone setting for each camera in a camera group (excluding doorbells)
  • Added support for Dark Theme for the Home, Event, and Event Filter pages in App Settings
  • Added support for Motion Warning Actions on multiple cameras in Rules
  • Added support for an interactive widget for Rule Shortcuts on iOS 17 and Android 14
  • Modified the validity period for Trusted Devices to 30 days
  • Optimized Thumbnail Show
  • Bug fixes
2.48.1.381 (January 8, 2024)
  • Fixed a bug that prevented connecting to Wyze Floor Lamp on Android 14 devices
2023
Android App 2023
2.48.0.379 (December 19, 2023)
  • Added support for Wyze Home Monitoring on Wyze Video Doorbell v2
  • Added support for Flash Light with Siren in Wyze Cam Floodlight Pro Settings
  • Optimized the live stream connection of Battery Cam Pro
  • Optimized the thumbnail show and timeline for Event Insight
  • Improved the UI for the in-app purchase page
  • Security improvements
  • Bug fixes
2.47.0.373 (November 15, 2023)
  • Added support for Trust Device when using Two-factor Authentication (2FA)
  • Added support for a “Battery Usage“ reminder pop-up when clicking the microSD card button for Wyze Battery Cam Pro
  • Added the Cam Plus Unlimited Plan to in-app purchase for more options
  • Optimized in-app purchase flow
  • Fixed the Event thumbnail download issue
  • Fixed the access error when changing Wyze Battery Cam Pro camera settings
  • Fixed a Wyze Bulb and Wyze Plug pairing issue
2.46.0.368 (October 19, 2023)
  • Added support for setting a motion detection zone in landscape mode on Wyze Battery Cam Pro
  • Improved UI for schedules with inverse actions in Rules
  • Improved UX when adding cameras to camera groups
  • Bug fixes
2.45.6.361 (September 28, 2023)
  • Fixed the bug that caused the Events tab to jump to the top after viewing Events
2.45.5.347 (September 25, 2023)
  • Added a Help button in the Cam Protect Settings page linking to the FAQs
2.45.0.342 (September 14, 2023)
  • Added support for OAuth login
  • Added support for Google and Apple ID login
  • Added support for Wyze Battery Cam Pro in Wyze Home Monitoring
  • Added steps when purchasing subscriptions to guide users through the process of linking their Cam Plus license to their device
  • Improved combined recording and notification settings for Wyze Cam OG
  • Improved the Google Play subscription experience
  • Fixed a Wyze Battery Cam Pro livestream bug that prevented loading camera groups when Power Saving was turned off
  • Fixed a bug that caused Error Code -5 when viewing Wyze Battery Cam Pro from a camera group
  • Bug fixes
2.44.5.330 (August 17, 2023)
  • Added a reminder to disarm Cam Protect to avoid receiving too many false alarms when Noonlight is contacted frequently in a short period of time
  • Fixed a bug that zoomed in on the Wyze Battery Cam Pro livestream after exiting Landscape Mode
  • Bug fixes
2.44.1.327 (August 8, 2023)
  • Fixed a bug that prevented Pixel phones using Android 13 from pairing Wyze devices with Bluetooth
  • Fixed a bug that prevented Wyze Video Doorbell Pro from going to the livestream from a push notification
2.44.1.326 (August 3, 2023)
  • Adjusted error reporting metrics
2.44.0.323 (August 1, 2023)
  • Added support for Dark Theme on Camera Livestream Pages and Event Detail Page
  • Added support for Picture-in-Picture for Wyze Cam Floodlight Pro and Wyze Battery Cam Pro
  • Added support for Wyze Video Doorbell and Wyze Video Doorbell Pro in camera groups
  • Updated the Cam Plus subscription performance
  • Fixed a bug that caused some Wyze Locks to show offline in the Home tab through they continued to function
  • Fixed a bug that prevented Wyze Switch pairing when using some Android devices
  • Bug fixes
2.43.5.313 (July 12, 2023)
  • Optimized the Cam Plus in-app-purchase flow
  • Fixed a bug that caused the Friendly Faces page to be blank
  • Bug fixes
2.43.0.312 (July 6, 2023)
  • Added support for multiple options in push notification sounds
  • Added support for “Things to Try“ after device setup
  • Added support for sharing product information with friends and family in Shop
  • Updated the Snooze Notification option
  • Fixed a bug that only allowed Wyze Scale to connect to Android devices with the app open
  • Bug fixes
2.42.5.294 (June 7, 2023)
  • Improved the Sound AI experience
  • Optimized the Cam Plus attachment flow on the Event viewing page
  • Bug fixes
2.42.0.292 (May 23, 2023)
  • Added support for Glass Breaking and Gun Shooting sound detection for Cam Protect customers
  • Added support for Smart Vision for Cam Protect customers
  • Added a reminder for Wyze Home Monitoring customers to check if a Permit Number is required by local authorities
  • Updated Security Camera logic in Home Monitoring so it displays the most recent footage of Motion, Person, or CO/Smoke Events of cameras used for Wyze Home Monitoring
  • Added support for auto-renew for Cam Plus customers who want to enable it in the app
  • Bug fixes
2.41.5 (April 26, 2023)
  • Added a control for the Wyze app notification sound under Push Notification Settings
  • Added support for Cam Protect in Canada
  • Optimized the services onboarding user experience
  • Optimized Event thumbnail information for customers without subscriptions
  • Bug fixes
2.41.0.200 (April 18, 2023)
  • Changed the notification sound for Wyze notifications so that they’re different than standard phone notification tones
  • Added support for an Event label for microSD card Playback for Wyze Cam OG
  • Added support for an enhanced global notification setting with a snooze function
  • Added support for showing the same SSID for combined 2.4 GHz and 5 GHz bands separately
  • Moved app security settings to Account > My Account in the Wyze app
  • Improved UI/UX for the Rule Action list
  • Improved the stability and workflow for Cam Protect
  • Optimized the Service page user experience and Cam Plus in-app purchase flow
  • Bug fixes
2.40.0.190 (March 8, 2023)
  • Added Rules support for Home Monitoring to use Mode changes and critical events as triggers to control your Wyze devices
  • Added support for Additional PIN that allows 10 additional PIN for Wyze Home Monitoring (firmware update required)
  • Improved Shortcut Rules UI/UX
  • Fixed a bug that caused thumbnails to rotate 90 degrees on the Home tab after setting up a doorbell
  • Fixed a bug that prevented Wyze Cam Outdoor v2 Event Videos from downloading properly when assigned as Wyze Home Monitoring Security Cameras
  • Bug fixes
2.39.0.179 (February 14, 2023)
  • Added a Request Dispatch icon on the live stream for Wyze Cam v2, v3, Pan, and Pan v2 that Cam Protect subscribers can use
  • Updated the Rules description for inverse actions
  • Optimized camera groups
  • Bug fixes
2.38.1.161 (January 5, 2023)
  • Improved the camera group experience
  • Bug fixes
2022
Android App 2022
2.38.0.153 (December 15, 2022)
  • Added support for email Two-Factor Authentication (2FA)
  • Added a new Wyze Cam onboarding with a Cam Plus free trial and opt-out option
  • Added Santa holiday AI detection to keep the magic alive
  • Added the ability to hold the Request Dispatch button in the Monitoring tab to immediately call for help
  • Removed the video verification process for Cam Protect armed systems in Test Mode
  • Improved UI in Rule Settings
  • Fixed a bug that prevented cancelling environment hazard remediation when Wyze Home Monitoring is Disarmed
  • Bug fixes
2.37.1.134 (November 28, 2022)
  • Fixed a bug that prevented the Cam Plus Apply License page from showing when a user tried to add a camera to their account with an existing Cam Plus subscription
  • Fixed a bug in the Create Rule page for sensor groups that showed a name error and caused the Rule action to fail
2.37.0.117 (November 17, 2022)
  • Cam Plus Pro is now Cam Protect!
  • Added a new alarm flow to Cam Protect that allows Noonlight agents to verify the video to help determine if there is a real threat
  • Added Rule Explore Tab to help customers explore how Wyze devices can work together to make your home smarter
  • Optimized the camera onboarding flow for Cam Plus users to improve the license binding experience
  • Fixed a bug that prevented sound when playing 12-second Cam Plus Lite videos
  • Fixed a bug that prevented Notification options from being selected correctly in Smart Support Tool
  • Fixed a bug that prevented users from adding devices to Smart Control on Wyze Switch
  • UI improvements
  • Bug fixes
2.36.0.96 (November 1, 2022)
  • Added support for Wyze Cam v3 Pro
  • Added support for Canadian addresses to enable Wyze Home Monitoring in Canada
  • Added AI Notifications for Wyze Cam v2, Wyze Cam v3, Wyze Cam Pan v1, and Wyze Cam Pan v2 with a firmware update to limit notifications to Events you care about
  • Added AI-only Events recording options for Wyze Cam v2, Wyze Cam v3, Wyze Cam Pan v1, and Wyze Cam Pan v2 on the latest firmware to allow control over what Events you want recording
  • AI notification and recording minimum firmware versions:
    • Wyze Cam v2 → 4.9.9.1273 and above
    • Wyze Cam v3 → 4.36.10.2000 and above
    • Wyze Cam Pan v1 → 4.10.9.1273 and above
    • Wyze Cam Pan v2 → 4.49.3.2000 and above
2.35.0.88 (September 29, 2022)
  • Cam Plus Pro is now supported on Wyze Cam Pan v2
  • Added support for Wyze Light Strip and Wyze Light Strip Pro effects outside of Music Mode
  • Added support for Wyze Bulb and Wyze Bulb Color effects outside of Music Mode when grouped with Wyze Light Strip or Wyze Light Strip Pro
  • Updated the Wyze Cam v3/Wyze Video Doorbell Pro Device Notification and Event Recording pages to remove inconsistencies
  • Fixed an inconsistency between the web and app versions of the Wyze Thermostat compatibility checker
  • Minor UI improvements
  • Bug fixes
2.34.0.75 (September 1, 2022)
  • Fixed a bug that prompted an app update when the app is on the most recent version
2.34.0.73 (August 24, 2022)
  • Added support for a delay between a person being detected on an armed camera and an alarm being triggered
  • Added support for Home/Away in Preset Rules
  • Added support for product search in Shop
  • Added support for Wyze Home Monitoring to Wyze Widgets
  • Added support for manual recording for adults to Wyze Scale S and Wyze Scale X
  • Added Wyze Cam Outdoor v1 and v2 compatibility to Smart Support Tool
  • Updated the Monitoring tab setup flow for accounts with a Cam Plus Pro license
  • Fixed a bug that caused the Playback entrance in Events to not work for some people
  • Bug fixes
2.33.1.162 (July 29, 2022)
  • Fixed a bug that prevented the Bluetooth connection permission window from appearing when connecting Wyze Watch
2.33.0.161 (July 21, 2022)
  • Added support for arming and disarming Cam Plus Pro devices using day/time schedules
  • Added more diagnostics for some commonly reported issues in the Smart Support Tool
  • Improved thumbnail image messaging
  • Fixed a bug that prevented the garage door status from refreshing automatically in the Home tab
  • Fixed a Cam Plus free trial bug
  • Bug fixes
2.32.0.154 (June 16, 2022)
  • Added support for Wyze Home Monitoring Emergency Contacts. Trusted friends and family members can be added to the list for additional security.
  • Added support for turning on Power and Lighting devices for X minutes as an action in Rules
  • Added a new Preset Rule that turns on lights if a person is detected with Cam Plus
  • Added additional Scenes for lighting products
  • Added support for Muscle Mass Rate and Pet Mode in Wyze Scale S and Wyze Scale X
  • Optimized the map display for Wyze Robot Vacuum
  • Fixed a bug that prevented Cam Plus Lite devices from using AI triggers in Rules
  • Fixed a typo in the Wyze Air Purifier installation instruction
  • Bug fixes
2.31.0.145 (May 18, 2022)
  • Added support for Wyze account deletion
  • Added support for grouping all Wyze lighting family products
  • Added Monitoring Schedule control toggles to allow pausing schedules for Wyze Home Monitoring
  • Added support for Wyze Cam Outdoor v2 in Wyze Home Monitoring (the Security Camera feature fix will be released later)
  • Added support for a Smart Support tool under Wyze Support to self diagnose device configuration issues (works only for Wyze Cam v3 with a Cam Plus license for now)
  • Added links to the Wyze communities
  • Improved the device sharing experience with people who don’t have Wyze accounts yet
2.30.1.141 (May 11, 2022)
  • Opened Cam Plus Pro to the public
  • Shop now uses the same platform as our website and the checkout experience has been adjusted
  • Bug fixes
2.30.0.130 (April 20, 2022)
  • Added support for Wyze Air Purifier (code merged in the 2.29 version)
  • Added support for Luggage Mode for Wyze Scale S
  • Added a 5-star rating in Cleaning History for Wyze Robot Vacuum
  • Added an FAQ page in Wyze Robot Vacuum Settings
  • Modified the date range for Export Data, Heart Rate measurement, and Set Goal for Wyze Scale S
2.29.2.127 (April 8, 2022)
  • Fixed a bulk update bug that would cause firmware updates to be available without following update order logic
  • Fixed a bug that caused Wyze Cam Outdoor to report incorrect status for microSD cards in the Base Station
2.29.1.116 (March 28, 2022)
  • Moved Cam Plus Lite’s position on the Services page to be easier to find
  • Removed the Cam Plus banner shown under snapshot Events and replaced it with a more contextually dynamic banner
  • Improved the Cam Plus license activation experience
  • Fixed an AI sound detection toggle bug
  • Fixed a bug that caused the Add Cameras button to disappear in the Cam Plus Lite section
2.29.0.114 (March 16, 2022)
General App:
  • Added support for Wyze Gun Safe
Wyze Video Doorbell Pro:
  • Added an additional field of view option for Wyze Video Doorbell Pro
Wyze Video Doorbell
  • Improved the experience of receiving Wyze Video Doorbell VOIP calls on a locked phone
Wyze Robot Vacuum:
  • Improved the Schedules page for Wyze Robot Vacuum
  • Added Smart Schedule recommendations based on cleaning activities for Wyze Robot Vacuum
Wyze Scale S:
  • Added a new real-time camera review to help locate the correct camera lens for heart rate measurement for Wyze Scale S
  • Added a custom date range option for data export for Wyze Scale S
Wyze Home Monitoring:
  • Added permit number support. If your local enforcement requires it, please apply for a monitoring permit and fill in the permit number in Home Monitoring Settings. Failing to do so may result in a refusal to dispatch from the police.
  • Added dispatch instructions support. If the entrance to your home is hard to navigate through, add dispatch instructions for quicker arrival.
Cam Plus:
  • Added Cam Plus auto-activation for bundle devices during device setup
Cam Plus Pro:
  • Updated the onboarding steps for new Cam Plus Pro users
2.28.2.111 (March 9. 2022)
  • Fixed a tablet crashing issue
2.28.1.109 (March 7, 2022)
  • Added support for Cam Plus Lite
  • Added support for thumbnail images for Wyze Cam Events for compatible cameras. Video clips are still available for devices using Cam Plus Lite.
2.28.0.102 (January 26, 2022)
  • Redesigned the Shop tab to be the single best place to shop for Wyze products
  • New limited-time Flash Sales let you score Wyze products at prices not possible before
  • Added support for Subscriber Discounts for those with Cam Plus and Cam Plus Pro
  • Added support for exclusive app shop coupons
  • Sorted products into categories to make browsing easier
  • New and popular products are now featured on the Shop tab’s main page
  • Added support for tracking shipped orders
  • Moved My Orders out of the Account tab and into the Shop tab
  • Added 30-second rewind and skip forward buttons in microSD card Playback for a better scrubbing/searching experience
  • Added the ability to group Wyze Bulb White and Wyze Bulb Color with Wyze Light Strip
  • Added support for multiple contact numbers in Wyze Home Monitoring for Noonlight to confirm alarms with shared users
  • Added the ability to group Wyze Sense Climate Sensors
  • Added individual AI notification toggles for Events with people, vehicles, packages, and pets detected
  • Updated the Cam Plus Free Trial UI
  • Bug fixes
2021
Android App 2021
2.27.33 (December 21, 2021)
  • Added Voice Over IP support for Wyze Video Doorbell
  • Added support for Rule recommendations
  • Added support for sharing Wyze Home Monitoring with people you trust
  • Added Sunrise/Sunset support for Wyze Lamp Socket
  • Added ceiling mount instructions for Wyze Cam Floodlight
  • Added a non-living things option in Baby/Pet Mode for Wyze Scale S
  • Added Wyze Plug and Wyze Plug Outdoor to the bulk update page
  • Added 5 Christmas song tones for Wyze Video Doorbell Pro
  • Updated app Sync Time to be compatible with old and new camera firmware versions
  • Improved instructions for measuring heart rate for Wyze Scale S
  • Fixed a firmware update bug for Wyze Plug Outdoor
  • Fixed a Schedule setting bug for Wyze Plug Outdoor
  • Fixed a battery display error for Wyze Cam Outdoor
  • Fixed a bug that prevented assigning Cam Plus to Wyze Video Doorbell Pro
  • Fixed a crashing bug when grouping Wyze Light Strip
Note: This app is being gradually released. If you do not see it now, you should see it later this week.
2.26.36 (December 8, 2021)
  • Fixed a crashing issue for Wyze Video Doorbell Pro
  • Fixed a Wyze Watch 47mm C face syncing bug
2.26.22 (November 11, 2021)
  • Added support for Wyze Video Doorbell Pro
  • Added support for Wyze Cam Lamp Socket
  • Added support for Wyze Cam Floodlight
  • Added support for heart rate measurement for Wyze Scale S
  • Added support for a beta tag for beta firmware in individual and bulk firmware update views
  • Make Your Voice Heard in Home Monitoring Settings welcomes you to give us feedback and learn what we are developing for you
  • Bug fixes
2.25.31 (November 3, 2021)
  • Added support for Wyze Watch 47mm C
2.25.22 (October 13, 2021)
  • Added support for Wyze Scale S
  • Added default options for room names for Wyze Robot Vacuum
  • Added support for the current year when inputting birth year for Wyze Scale
  • Added Monitoring Schedule in Home Monitoring for routine arming and disarming convenience without using the Keypad or your phone
  • Fixed a siren countdown bug for Wyze Cam v3
  • Fixed a bug that distorted zoomed-in video image for Wyze Cam v3
  • Fixed a crashing bug when sorting devices within Wyze Bulb Color groups
  • Fixed a bug that displayed different temperature on the Home tab and device page for Wyze Leak Sensor
  • Fixed a bug that prevented temperature refreshing for Wyze Climate Sensor
(Wyze Cam Outdoor firmware 4.16.2.26 and Base Station firmware 4.17.1.287 required for the below 2)
  • Improved Cam Plus performance for Wyze Cam Outdoor
  • Fixed the flashing blue light issue for Wyze Cam Outdoor Base Station
2.24.51 (September 16, 2021)
  • Added support for Wyze Light Strip Pro
  • Added Trends for Wyze Home Monitoring to show how you use the service to protect the things you care about
  • Added support for Wyze Home Monitoring users to change names in Monitoring Settings after setup
  • Lifted the mandatory Keypad + one sensor limit for Wyze Home Monitoring Sense Hub setup
  • Added the ability to set up Wyze Home Monitoring from the Home tab Add Device page
  • Added a Mic Noise Reduction toggle for Wyze Buds
  • Changed the "Energy" EQ mode to "Sport" for Wyze Buds
  • Bug fixes
2.24.23 (September 1, 2021)
  • Added support for Wyze Buds
  • Added support for Sunrise/Sunset in Rules (This update is being sent to a limited number of users at first and will be more widely available later.)
  • Added support for Wyze Leak and Climate Sensors in Rules (This update is being sent to a limited number of users at first and will be more widely available later.)
  • Added support for Wyze Leak and Climate Sensors for Wyze Home Monitoring
  • Redesigned Wyze Bulb UI
  • Added a Wyze Lock button to the Wyze Video Doorbell page
  • Added more detail options such as a tree or crop types and growth stages to Wyze Sprinkler Controller Smart Schedules
  • Optimized the in-app purchase experience
  • Fixed a Playback bug for Wyze Cam v3
  • Fixed a bug that caused the app to crash when accessing camera groups
  • Bug fixes
2.23.21 (August 4, 2021)
  • Added support for Wyze Buds Pro
  • Added support for Wyze Leak Sensor
  • Added support for Wyze Climate Sensor
  • Added support for location-based Rules triggers based on arrival or departure from a location
  • Added support for unlocking Wyze Lock from the Wyze Video Doorbell page
  • Added support for repeat schedules for Wyze Sprinkler Controller
  • Added animation playback and sharing for Wyze Robot Vacuum
  • Added weight comparison to the Wyze Scale page
  • Fixed a bug that prevented downloading time lapse videos for Wyze Cams
  • Fixed a bug that prevented live streaming on the Wyze Home Monitoring Security Camera page
  • Bug fixes
Note: The location-based Rules triggers are being rolled out gradually. If you do not have it available today, you should get access in the next 3 weeks.
2.22.31 (July 28, 2021)
  • Changed minimum app operating system (OS) compatibility from Android 5.0+ to 7.0+
  • Bug fixes
Note: The minimum OS change will not affect apps already downloaded onto your device. If your operating system is below the threshold, you will not be able to see future app updates in the app store. This change is being made to support upcoming security changes and features. We encourage you to update your OS at your earliest opportunity and apologize for any inconvenience.
2.22.21 (July 12, 2021)
  • Improved the Message Center
  • Added an SMS option for Wyze News and Promos
  • Optimized Device List UI
  • Added Wyze Watch 44 and 47mm to the bulk firmware update page
  • Optimized Wyze Floor Lamp setup logic and Device tab UI
  • Bug fixes
2.21.27 (June 24, 2021)
  • Fixed an issue that may cause slow app response
2.21.26 (June 16, 2021)
  • Updated the button design for non-subscribers in the Monitoring tab
2.21.25 (June 14, 2021)
  • Added Siren support and a Battery Usage Summary for Wyze Cam Outdoor (requires Wyze Cam Outdoor firmware version 4.17.1.123 and Base Station: 4.16.2.7)
  • Added a low battery indicator for Wyze Sense v2
  • Added a Vacation Mode indicator for Wyze Bulb Color
  • Added support for Wyze Lock Google Home integration
  • Improved Smart Schedule for Wyze Sprinkler Controller
  • Enabled no-go zone rotation for Wyze Robot Vacuum
  • Enabled app sorting for Wyze Watch 44mm
  • Enabled bulk editing schedules for Wyze Floor Lamp
  • Fixed a bug that displayed the 12s limit icon for Cam Plus users
  • Fixed a detection zone setting bug for Wyze Cam v2
  • Fixed a bug that prevented Event videos from playing for Wyze Video Doorbell
  • Fixed a bug that prevented Wyze Video Doorbell Live Stream for Wyze Home Monitoring
  • Bug fixes
2.20.21 (May 12, 2021)
General App:
  • Added support for Wyze Floor Lamp
  • Added a red dot indicator for beta users when a new product enters Beta Program
  • Added support for phone numbers changes in Wyze Home Monitoring
  • Fixed a bug that prevented iOS users from going through the setup flow after resetting Wyze Home Monitoring
  • UI improvements
  • Bug fixes
Wyze Thermostat (firmware update required):
  • Added support for Fan Activation Delay
  • During Auto mode, when the user sets a heating and cooling temperature difference less than 5°F, the temperature will change automatically when either one is changed
  • Moved Fan Cycle to Advanced Settings and added further in-app information
  • The Fan Cycle interval is now changed to 0-30 min/hour. The default value is 0 min/hour
Wyze Video Doorbell (firmware update required):
  • Added support for Quick Replies for Wyze Video Doorbell
2.19.15 (April 22, 2021)
  • Improved the update instructions for Wyze Sense Keypad
  • Improved Home page data loading for Wyze Home Monitoring
  • Fixed bugs that caused the user to get stuck during setup for Wyze Home Monitoring
  • Fixed a count down issue for Wyze Home Monitoring
  • Fixed a notification setting bug for Wyze Watch 44mm and 47mm
2.19.14 (April 8, 2021)
  • Added support for a custom motion detection zone for Wyze Cam v3 (future firmware update required)
  • Added support for Wyze Cam being used as a zone image for Wyze Sprinkler
  • Enabled room selection when idle and disabled room selection when cleaning for Wyze Robot Vacuum
  • Improved map creation and management for Wyze Robot Vacuum
  • Improved the setup process for Wyze Video Doorbell
  • Fixed a time zone setting bug for Wyze Bulb Color schedules
  • Fixed a bug that caused the app to crash when bulk updating Wyze Plug Outdoor
  • Fixed a bug that caused inconsistency in the Beta Program product list
  • Fixed incorrect personal information for Wyze Watch 47mm
  • Fixed a bug that continued to prompt Wyze Home Monitoring firmware updates when fully updated
  • Fixed a bug that prevented auto-unlock from functioning properly for Wyze Lock
2.18.41 (March 25, 2021)
  • Added support for Home Monitoring Service
  • Added support for Wyze Entry Sensor v2
  • Added support for Wyze Motion Sensor v2
  • Added support for Wyze Sense Hub
  • Added support for Wyze Sense Keypad
  • Added support for Home hub
2.18.18 (March 9, 2021)
  • Added support for Wyze Bulb Color
  • Added support for a detection zone for Wyze Video Doorbell (firmware update required)
  • Modified the map drag range for Wyze Robot Vacuum
  • Added Wyze Support to the Wyze Robot Vacuum Settings page
  • Bug fixes
2.17.41 (February 24, 2021)
  • Fixed a bug that prevented Wyze Robot Vacuum users from dragging the map
  • Fixed a bug that prevented Wyze Robot Vacuum users from dividing rooms
  • Bug fixes,/span
2.17.7 (January 26, 2021)
  • Added support for Wyze Sprinkler
  • Added support for the Wyze Cam v3 Spotlight
  • Added a motion detection zone record sound toggle for Wyze Cam Outdoor
  • Added support for Wyze Cam Outdoor motion-only scheduled local recordings
  • Added support for the Base Station to connect over WiFi
  • Added support for changing the name of Wyze Headphones
  • Improved Map & Virtual Wall functions for Wyze Robot Vacuum
  • Made vehicle package detection available to all Cam Plus users
  • Added product categories to help users find their device easily during setup
  • Added support for Device and Device List widgets
  • Optimized Wyze Plug and Wyze Plug Outdoor setup UI
  • Fixed a bug that caused Wyze Band to connect instead of Wyze Watch devices
  • Unified the device/platform feedback support experience
  • Bug fixes
2.16.55 (January 16, 2021)
  • Added compatibility with cloud-side changes
  • Optimized setup for Wyze Headphones
  • Fixed a bug causing the Map to freeze for Wyze Robot Vacuum after an extended cleaning cycle
2020
Android App 2020
2.16.23 (December 16, 2020)
  • Added support for Wyze Thermostat
  • Added support for Wyze Robot Vacuum
  • Added support for Wyze Plug Outdoor
  • Added support for Beta Program
  • Added support for changing the Wyze account email
  • Added the Home Monitoring tab
  • Updated the Account tab UI
  • Added support for Wyze Cam v3 to record videos when triggered by Wyze Sense
  • Added the ability to control marketing messages in Wyze app
  • Bug fixes
Note: This app may take a day to become available depending on the length of the app store review process.
2.15.51 (December 2, 2020)
  • Fixed a bug that caused Wyze Headphones updates to take longer than expected
2.15.21 (November 9, 2020)
  • Added support for Wyze Headphones
  • Added support for fast forward for Cam Plus Event videos
  • Added Wyze Band, Lock, and Scale to the bulk firmware update page
  • Updated Wyze Support in the Account tab
  • Added a WiFi/Bluetooth connection status to Wyze Lock
  • Added the ability to set up and edit weight goals to Wyze Scale
  • Bug fixes
Note: This app may become available to you later depending on when the app store releases it to the public.
2.14.35 (October 20, 2020)
  • Fixed a bug that caused difficulty viewing the live stream with Android 11
2.14.33 (October 13, 2020)
General app:
  • UI improvements for the bulk firmware update page
  • Added a pop-up notification when manually rotating Wyze Cam Pan with Detection Zone enabled
  • Added a running in the background option in the App Settings page
  • Closed the Person Detection pilot
  • Bug fixes
Wyze Band:
  • Added a pop up reminder when a firmware upgrade is available
  • Added a "mute when screen is on" function so that Wyze Band will stop vibrating and showing notifications when you are already processing those messages on your mobile device.
  • UI improvements
2.13.119 (September 14, 2020)
  • Fixed a bug that caused the Event page to go back to the top after viewing an Event video
  • Fixed a bug that caused the location permission pop-up to occur repeatedly
  • Fixed a bug that prevented new devices from being available in the Event filter
  • Fixed the screen ratio for some devices with smaller screens
  • Fixed a bug that prevented the live stream from progressing through 3/3 if the app was left on in the background
2.13.118 (September 9, 2020)
General App:
  • Improved the Event page UI Event filter
  • Added support for backup 2FA phone number verification
  • Added the ability to change Wyze Bulb settings without turning the bulbs on with Rules
Wyze Sense:
  • Added support for low battery status notification
Wyze Scale:
  • Added support for pairing multiple scales to one account
  • Added support for data export
Wyze Band:
  • Added a Tool Box feature with Stopwatch and Flashlight
  • Improved heart rate and sleep tracking accuracy
2.12.35 (August 17, 2020)
General App:
  • Fixed a bug causing Cam Plus to not refresh after device setup
  • Changed the default keyboard for login
  • Adjusted the ratio for iPhone X
  • Minor UI/UX improvements
Wyze Cam Outdoor:
  • Fixed a Wyze Cam Outdoor bug that caused the app to show false success when disabling Travel Mode
  • Fixed a bug that prevented some Wyze Cam Outdoor cameras from reading the microSD card
  • Removed the photo access permission request when viewing the Wyze Cam Outdoor live stream
  • Fixed a bug that prevented the Wyze Cam Outdoor thumbnail from updating
Wyze Cam v2 and Pan:
  • Fixed an Album bug that prevented updating the Album after deleting a time lapse video
2.12.29 (July 29, 2020)
General App:
  • Added the new Cam Plus service. Now you can use Person Detection with Complete Motion Capture!
Wyze Bulb:
  • Added support for Sleep Routines
  • Added a Reconnect button for if Wyze Bulb goes offline
Wyze Band Released Features:
  • Added Google Fit and Apple Health data integration
Wyze Band Features Available After An Upcoming Firmware Update:
  • Added a freestyle exercise mode
  • Added support for 12hr/24hr time format change
  • Added support for the red dot notification
Wyze Scale:
  • Added Fitbit data integration
  • Added trends for more body metrics
  • Improved the algorithm
Wyze Lock:
  • Added “Submit feedback” for guest accounts
  • Added a warning for when there are over 50 passwords stored on the keypad
  • Auto-unlock history now shows which user activated it
2.11.40 (June 10, 2020)
  • Updated the Event page UI
  • Added a new opened/closed door state notification for Wyze Lock
  • Improved auto-unlock
  • Bug fixes
Please note that Google has cautioned us to expect app reviews to take 7 days or longer during this time. If you do not see the update now, you should receive it in the next week or so.
2.10.80 (May 20, 2020)
  • Fixed a timezone bug that caused an unnecessary notification for some users
2.10.74 (May 11, 2020)
  • Fixed a bug causing a persistent notification for people not using Wyze Band
2.10.72 (May 7, 2020)
  • Added support for the Emergency Button (Pilot)
  • Improved Wyze Lock geofencing
  • Improved UI for Wyze Band and Scale
  • Bug fixes
2.10.36 (April 21, 2020)
  • Added a TOTP option for 2FA
  • Unified the log submission flow<></>
  • Added person detection support for Wyze Cam v1
  • Added person detection support for RTSP firmware
  • Improved the UI for the Home page
  • Added an in-app rating
  • Added support for Google Fit integration for Wyze Scale
  • Bug fixes
We are pleased to say that the Wyze Cloud Person Detection AI beta is now available for all Wyze users. This is still considered a beta version because we have some further improvements in development.
2.9.70 (April 7, 2020)
  • Fixed an issue preventing some tablets from seeing the app in Google Play
  • Bug fixes
2.9.62 (March 31, 2020)
  • Added support for Wyze Band
  • Bug fixes
2.9.30 (March 18, 2020)
  • Fixed a bug that caused the live stream to freeze when using hardware decoder
  • Bug fixes
2.9.29 (March 9, 2020)
  • Added support for hardware decoder under App Settings
  • Fixed auto-unlock accuracy bugs
  • Fixed a lock status accuracy bug on the Home tab
  • Other bug fixes
  • Added support for our Cloud AI Person Detection beta.
2.8.24 (January 27, 2020)
  • Prepared for XNOR removal with the firmware upgrade
  • Improved the device setup experience
  • Added suggested device names
  • Added "eject microSD card"
  • Added keypad support for Wyze Lock
  • Added power loss status recovery for Wyze Bulb
  • Added recommendations to update very old Wyze Cam firmware
Pre-2020
Android App Pre-2020
2.7.19 (December 17, 2019)
  • Wyze Lock integration
  • Deleting devices now removes Event videos from shared user accounts
  • Event videos are now saved for 14 days even if the Wyze Cam is deleted
  • Added in-app request to review Complete Motion Capture after free trial
  • Removed the gray overlay from Event videos
  • Fixed a bug preventing zooming in on Event videos
2.6.42
  • Added Complete Motion Capture
  • Added overnight scheduling to Rules
  • Added labels to Schedules and Device Triggers in Rules
  • Added a conditional schedule for device trigger Rules
  • Event videos are now available even if the Wyze Cam is removed from the account
  • Improved sharing experience
  • Added linking to Alexa from the Wyze app
  • Added phone number input to Shop
  • Added comment reply notifications for Shop and Discover
  • Bug fixes
2.5.36
  • Improved the video lag issue when viewing the live stream, Playback, or Event videos
  • Security updates
2.5.30
  • Fixed an issue may cause the app log to not generate when reporting an issue
2.5.29
  • Fixed an issue that may cause failures when creating Schedules with end times
2.5.28
  • Redesigned automation for lifestyle optimization with shortcuts, schedules, and device triggers
  • Improved experience for sharing devices and managing shared devices
  • Added support for Wyze Sense Bridge and Wyze Plug in firmware bulk upgrade
  • Added product badges under Account tab
  • Fixed an issue that may cause mic permission use when the app is running in the background
2.4.82
  • Added Person Detection. Your Wyze Cam can now detect people and send notifications when a person is detected. (latest firmware required, only Wyze Cam v2 and Pan are supported)
  • Added 'Is left closed for' option for contact sensor notifications
  • Added a status light toggle for Wyze Sense Bridge (latest firmware required)
2.4.24
  • Added Wyze Bulb support
  • Added group action support for Shortcuts
  • Added thumbnails for notifications
  • Added a comment feature in Discover
  • Added a report feature in Discover
  • Fixed the Wyze Cam Pan two-way audio issue on some Samsung phones
  • Improved the experience for Wyze Cam Pan when connecting to a Bluetooth device
2.3.69
  • Added grouping support for Wyze Sense
  • Added sound for simultaneous streaming
  • Added new triggers and actions for Wyze Sense in Shortcuts
  • Fixed the screen hibernation issue when streaming individual cameras
2.3.16
  • Added Two-Factor Authentication
  • Added device on/off button to the Home page
  • Added offline status
  • Added a download button for Event videos
  • Added support for RTSP (special firmware required)
  • Improved access for individual cameras during simultaneous streaming
2.2.38
  • Added the ability to create camera groups
  • Added the ability to stream multiple Wyze Cams at once through groups
2.1.31
  • Added IR light control
  • Added support for sorting and likes in Discover
  • Added Early Access feature in Shop
  • Optimized the log out issue when in poor internet connection
  • Improved aspect ratios for devices that aren’t 16:9
  • Fixed the zoom issue when enabling Hardware Decoder
  • Bug fixes and experience improvements
2.1.27
  • Allow bulk firmware upgrades through Account
  • Support PayPal payment in Shop
  • Improved experience for device setup and Forgot Password
  • Improved experience when using Bluetooth devices
  • Bug fixes
2.0.26
  • Fixed an issue where some small screen devices were not seeing the "Sign up" link on the login screen
  • Fixed a calendar bug in the Events tab
  • Fixed a bug where setting up devices was causing the app to crash
2.0.23
  • Changed device list design, 1 or 2 devices for tile view, 3 or more devices for list view
  • Enlarged thumbnails in event list view
  • Changed Do Not Disturb on/off text to Notifications off/on
  • Added newsletter subscription UI in Accounts
  • Removed 'Notification' info in device list page
  • Fixed a hardware decoding crash on some Android 5.1 devices
  • Bug fixes
1.5.44
  • Fixed a bug that caused app crashes on Android Lollipop (5.0 and 5.1)
1.5.42
  • Known issue: App crashes at the splash screen with Android OS 5.0 or 5.1. A fix is coming
  • Added the previous and next buttons in Playback to jump to events for "record on event" setting or skip time on "continuous recording" setting
  • Added alert video thumbnails for Wyze Cam v2 and Pan
  • Added WiFi signal strength in Device Info
  • Added automation tasks and shortcuts in My Account
  • Added double tap zoom
  • Added 'show Wyze logo' toggle
  • Added 360p option for Wyze Cam v2 and Pan cameras for slow internet connection
  • Changed that shared users won't be able to view shared cameras immediately after share is canceled by main users.
  • Changed that if the camera status is changed by one user, the camera status for all users
  • with access will be updated
  • Fixed an issue that users can't toggle off all day in the alert schedule
  • UI changes and other bug fixes
1.4.43
  • Fixed a bug that camera settings weren’t saved correctly
  • Fixed a bug that caused an empty alert video list
  • Fixed an issue that caused refresh list error
  • Other bug fixes
1.4.33
  • Added turn on/off camera functionality
  • Added ‘restart’ in camera setting page
  • Moved the ‘Sort’ button to top right of device list
  • Clicking on notification goes directly to alert video
  • Add a prompt when receiving camera share
  • Allow sending firmware log via app
  • Add IP address in Device Info
  • Added Wyze Newsletter subscription under Account page
  • UI changes & bug fixes
1.3.162
  • Added app support for Wyze Cam Pan
  • New setup experience for Pan
  • Pan/tilt support in live streaming
  • New Motion Tracking feature
  • New Pan Scan feature
  • New two-way speaking for Pan
1.3.123
  • Device sorting
  • Motion Detection Zone (need firmware update)
  • Swiping left/right to switch between alerts
  • Adjusting motion/sound sensitivity from H/M/L to a 1-100 slider (need firmware update)
  • Turning sound recording on/off (need firmware update)
  • Switching to use Google notification service
  • UI changes and bug fixes
  • Minimum firmware requirements:
  • Wyze Cam v2 – V4.9.1.42
  • Wyze Cam v1 – V3.9.3.62
1.2.76
  • Fixed the issue of 1-hour shift when setting an alert schedule
  • Removed an unnecessary sound check when closing live view
1.2.71
  • pdated Daylight Savings Time handling
  • Bug fixes
1.2.58
  • App update for Wyze Cam V2
  • Fixed two timelapse download issues
  • Enabled hardware decoding
  • Bug fixes
1.2.50
  • Simplified alert logic for better alert and notification stability
  • Enable recording and pause/resume in playback
  • Support screen rotation
  • Multiple phones/tablets using the same Wyze account will all receive alert notifications. (In V1.1 only one device is notified)
  • Option to turn on/off timestamp watermark in video frame
  • Enable microSD card format
  • Provide hardware decoding option
  • Bug fixes
iOS App
2026
iOS App 2026
3.23.2.1 (October 13, 2026)
  • Bug fixes
3.23.1.3 (October 5, 2026)
  • Bug fixes
3.23.0.16 (September 30, 2026)
  • Bug fixes
3.22.0.35 (September 16, 2026)
3.21.1.2 (September 4, 2026)
3.21.0.16 (August 31, 2026)
  • Bug fixes.
3.20.0.20 (August 24, 2026)
  • Bug fixes.
3.19.0.17 (August 11, 2026)
  • Bug fixes.
3.18.0.15 (July 23, 2026)
  • Bug fixes.
3.17.0.13 (July 14, 2026)
  • Bug fixes.
3.16.0.20 (June 25, 2026)
  • Bug fixes.
3.15.0.20 (June 16, 2026)
  • Bug fixes
3.14.0.56 (May 27, 2026)
  • Bug fixes
3.13.0.18 (May 4, 2026)
  • Added support for iOS lock screen widget
  • Bug fixes
3.12.0.6 (April 23, 2026)
  • Bug fixes
3.11.6.1 (April 6, 2026)
  • Bug fixes.
3.11.5.4 (March 31, 2026)
  • Bug fixes.
3.11.0.6 (March 23, 2026)
  • Bug fixes.
3.10.5.2 (February 2, 2026)
  • Bug fixes
3.10.0.9 (January 22, 2026)
  • Widgets support Clear and Tinted mode
  • Bug fixes
2025
iOS App 2025
3.9.1.1 (December 23, 2025)
  • Optimized Wyze Window Cam setup experience
3.9.0.7 (December 15, 2025)
  • Improved the setup and management flow for adding Wyze Shortcuts to Siri on iOS.
  • Bug fixes.
3.8.7.3 (November 19, 2025)
  • Bug fixes
3.8.5.11 (November 3, 2025)
  • Bug fixes
3.8.1.1 (October 20, 2025)
  • Bug fixes
3.8.0(6) (October 16, 2025)
  • Bug fixes
3.7.6.2 (September 8, 2025)
  • Bug fixes
3.7.5.4 (September 2, 2025)
  • Bug fixes
3.7.0.8 (August 27, 2025)
  • Ability to add Wyze Shortcuts directly to Siri.
  • Bug fixes.
3.6.5.5 (July 17, 2025)
  • Bug fixes.
3.6.0.6 (July 8, 2025)
3.5.5.8 (May 29, 2025)
3.5.1.4 (May 25, 2025)
  • Bug fixes
3.5.0.8 (May 15, 2025)
  • Bug fixes
3.4.5.9 (April 16, 2025)
3.4.0.11 (March 26, 2025)
  • Bug fixes
3.3.6.61 (February 25, 2025)
  • Fixed an issue that prevented filtering of Unknown faces in the Events tab (iOS Only)
3.3.5.5 (February 20, 2025)
  • Bug fixes
3.3.0.6 (January 13, 2025)
  • Bug fixes
2024
iOS App 2024
3.2.7.1 (December 4, 2024)
  • Fixed an issue that caused an error code -17 when viewing the live stream on Wyze Battery Cam Pro and Wyze Cam Floodlight Pro
3.2.6.1 (November 19, 2024)
3.2.5.9 (November 14, 2024)
3.2.2.1 (November 8, 2024)
3.2.1.3 (October 30, 2024)
  • Bug fixes
3.2.0.9 (October 22, 2024)
  • Bug fixes
3.1.6.1 (September 24, 2024)
  • Bug fixes
3.1.5.6 (September 23, 2024)
  • Bug fixes
3.1.0.6 (September 9, 2024)
  • Bug fixes
3.0.5.9 (August 21, 2024)
  • Bug fixes
3.0.0.16 (July 24, 2024)
  • Bug fixes
2.50.9.1 (July 16, 2024)
2.50.7.10 (May 28, 2024)
2.50.6.1 (April 29, 2024)
  • Fixed the issue where each video in the event list is separated
2.50.5.4 (April 25, 2024)
  • Fixed an issue where the user clicking the siren button on Wyze Battery Cam Pro was not working (iOS ONLY)
2.50.1.1 (April 2, 2024)
2.50.0.17 (March 25, 2024)
  • Added support for using long press to snooze Event Video notifications
  • Bug fixes
2.49.2 (2) (February 7, 2024)
  • Optimized backend metrics
2.49.1.1 (February 1, 2024)
  • Optimized dark theme (iOS-only)
  • Bug fixes
2.49.0.4 (January 25, 2024)
  • Bug fixes
2.48.5.1 (January 8, 2024)
  • Fixed a backend issue that did not affect the customer experience
2023
iOS App 2023
2.48.0.6 (December 19, 2023)
  • Bug fixes
2.47.0.6 (November 15, 2023)
2.46.1.4 (October 31, 2023)
  • Fixed a bug that caused the Event timeline to play when the app was in the background
2.46.0.6 (October 19, 2023)
  • Bug fixes
2.45.5.4 (September 25, 2023)
2.45.1.1 (September 14, 2023)
  • Bug fixes
2.44.5.3 (August 17, 2023)
  • Fixed a bug that hid Events when returning to the Event tab
  • Fixed a bug that prevented some users from sharing devices
  • Bug fixes
2.44.1.1 (August 3, 2023)
  • Fixed a livestream bug that prevented viewing individual cameras from a camera group
  • Fixed an app crash when entering the last Event to capture a photo in Smart Vision
  • Fixed a bug that prevented audio when holding the Speak button
2.44.0.6 (August 1, 2023)
  • Fixed an Event Recording push notification bug that led to an incorrect page
  • Fixed a bug that caused Playback to start at the most recent part of the timeline from an Event Video instead of the actual time of the recording
  • Bug fixes
2.43.5.3 (July 12, 2023)
  • Fixed a bug that caused the Event page to reset to the top after viewing Events
  • Bug fixes
2.43.0.12 (July 6, 2023)
  • Fixed a bug that prevented Wyze Cam v3 from using microSD card Playback
  • Fixed a bug that prevented Wyze Scale firmware updates for iOS
  • Bug fixes
2.42.6.1 (June 13, 2023)
  • Fixed an issue that caused a crash in camera groups
2.42.5.2 (June 7, 2023)
  • Fixed a bug that hid the latest date in the Event tab
  • Bug fixes
2.42.0.24 (May 26, 2023)
  • Added support for landscape mode on iPad for the Home tab
2.42.0.23 (May 25, 2023)
  • Experience improvements on iPad
  • Bug fixes
2.41.5.5 (April 26, 2023)
  • Bug fixes
2.41.0.28 (April 18, 2023)
  • Bug fixes
2.40.0.15 (March 8, 2023)
  • Added Rules support for Wyze Home Monitoring to use Mode changes and critical events as triggers to control your Wyze devices
  • Fixed a bug that prevented the removal of previous Wyze Thermostats
  • Fixed a landscape aspect ratio issue on iPad
  • Fixed a bug that caused Location Trigger names to display incorrectly in Rules
  • Fixed an aspect ratio issue in the tab bar
  • Bug fixes
2.39.0.20 (February 14, 2023)
  • Bug fixes
2.38.4.3 (January 11, 2023)
  • Fixed a bug that frequently caused Error Code -1 when viewing camera groups
2.38.3.3 (January 5, 2023)
  • Bug fixes
2022
iOS App 2022
2.38.2.1 (December 22, 2022)
  • Fixed the incorrect beta tag in the app name<></>
2.38.1(28) (December 21, 2022)
  • Fixed a crash that happened on the Home tab for some users
  • Fixed a broken in-app purchase link on Event Video pages
Note: This app version will say WyzeBeta though it is not a beta release. We apologize and will submit a new version with the updated name tomorrow.
2.38.0.27 (December 15, 2022)
  • Added validation to check if the Wyze app has authorization for notifications and Critical Alerts for Wyze Home Monitoring
  • Bug fixes
2.37.2.1 (November 28, 2022)
  • Fixed an issue that prevented Canadian users from setting up Wyze Home Monitoring
2.37.1.1 (November 21, 2022)
  • Fixed a bug that caused the camera Live page to show a black screen in landscape mode
  • Fixed a bug that caused sound in motion Event Videos for Wyze Video Doorbell Pro if it’s muted for the first time
2.37.0(12) (November 17, 2022)
  • Fixed a bug that caused AI filters to stay in Events even if the app is closed
  • UI improvements
  • Bug fixes
2.36.0.14 (November 1, 2022)
2.35.0.13 (September 29, 2022)
  • Bug fixes
2.34.1.1 (September 1, 2022)
2.34.0.15 (August 24, 2022)
  • Bug fixes
2.33.0.17 (July 21, 2022)
  • Bug fixes
2.32.0.20 (June 16, 2022)
  • Bug fixes
Note: This app version and newer requires iOS 14.
2.31.1.0 (May 23, 2022)
  • Fixed a bug that prevented updating phone numbers for Cam Plus Pro
2.31.0.7 (May 18, 2022)
  • Fixed a Wyze Cam Outdoor bug that prevented Settings from loading correctly
2.30.1.10 (May 11, 2022)
  • Fixed a grouping bug for Wyze Cam Outdoor that prevented the live stream from loading or mixed up camera names
  • Bug fixes
2.30.0.14 (April 20, 2022)
  • Added support for Wyze Air Purifier (code merged in the 2.29 app)
  • Fixed a bug that showed incorrect cooldown options for Wyze Cam Outdoor with Cam Plus
2.29.2 (April 8, 2022)
2.29.1 (March 28, 2022)
2.29.0 (March 16, 2022)
General App:
Wyze Robot Vacuum:
Wyze Scale S:
Cam Plus:
Cam Plus Pro:
2.28.2 (March 7, 2022)
2.28.0 (January 26, 2022)
  • Bug fixes
2.27.37 (January 18, 2022)
  • Added support for Person Detection on more devices
2.27.34 (January 6, 2022)
2.27.33 (January 3, 2022)
  • Fixed a crash issue on iOS 12
2021
iOS App 2021
2.27.32 (December 21, 2021)
  • Fixed a bug that caused Shortcuts to disappear
  • Fixed a crash issue for Wyze Band when tapping on the heart in Activity
2.26.21 (November 11, 2021)
  • Bug fixes
2.25.32 (November 3, 2021)
2.25.21 (October 13, 2021)
  • Fixed a crashing bug in landscape mode for Wyze Cam v3
  • Fixed a bug that prevented adding Wyze Lock in Accessories for Wyze Video Doorbell
  • Fixed a bug that prevented non-Cam Plus videos from playing in Events
2.24.52 (September 16, 2021)
  • Bug fixes
2.24.36 (September 8, 2021)
  • Fixed a bug that prevented connecting to the Wyze Cam Outdoor Base Station using Wi-Fi
2.24.34 (September 1, 2021)
  • Fixed a bug that prevented executing Wyze Bulb scenes created in older app versions
  • Fixed a bug that prevented Wyze Cam v3 videos stored in Album from being opened
  • Fixed a pairing bug for Wyze Leak Sensor
  • Fixed an AI settings bug for Wyze Cam Outdoor
  • Bug fixes
2.23.23 (August 12, 2021)
  • Fixed a bug that prevented the full descriptions of Wyze Scale metrics from displaying
  • Fixed a bug that prevented Wyze Buds Pro from pairing
  • Fixed a bug that prevented users from purchasing an annual subscription in the app
  • Prevented firmware updates when Wyze Cam Outdoor has low battery
  • Fixed an issue that prevented Wyze Cam Outdoor Base Station setup
  • Fixed a bug that displayed the 12s limit icon for Cam Plus users in Sound Events
  • Bug fixes
2.22.32 (July 28, 2021)
  • Changed minimum app operating system (OS) compatibility from iOS 9.0+ to 12.0+
  • Bug fixes
  • Bug fixes
2.21.35 (June 16, 2021)
2.21.33 (June 14, 2021)
  • Fixed an audio loss bug for Wyze Cam v2 and Pan manually recorded videos
  • Bug fixes
2.20.142 (May 12, 2021)
General App:
  • UI improvements
  • Bug fixes
2.19.24 (April 20, 2021)
  • Fixed a bug that caused the camera to trigger false alarms for Wyze Home Monitoring
2.19.22 (April 8, 2021)
  • Fixed a bug that prevented Wyze Cam Outdoor’s Base Station from connecting to WiFi if the SSID has a special character
  • Fixed a bug that caused app crashes when viewing Wyze Video Doorbell in landscape mode (iOS 13 and below)
2.18.44 (March 31, 2021)
  • Updated the Wyze Cam Outdoor location popup to only occur when using Travel Mode
2.18.43 (March 25, 2021)
  • Reduced static sound when using iOS to view Wyze Cam v3 live streams
2.18.23 (March 12, 2021)
  • Fixed a service purchase issue
2.18.21 (March 9, 2021)
  • Bug fixes
2.17.42 (February 24, 2021)
  • Bug fixes
2.17.21 (January 26, 2021)
  • Added support for the Base Station to connect over Wi-Fi
  • Improved Map Virtual Wall functions for Wyze Robot Vacuum
  • Bug fixes
2.16.48 (January 22, 2021)
  • Fixed an issue that prevented Wyze Robot Vacuum setup
2.16.46 (January 16, 2021)
  • Fixed the bug causing a freeze in the landing page after extended time without using the Wyze app
  • Optimized the Event video player
  • Moved map editing to the Settings page for Wyze Robot Vacuum
  • Optimized Map editing UI for Wyze Robot Vacuum
2020
iOS App 2020
2.16.25 (December 22, 2020)
  • Fixed a bug which set the wrong time for Device Trigger Rules
  • Bug fixes
2.15.41 (November 18, 2020)
  • Improved Wyze Cam v3 connectivity
  • Add support for Wyze Cam v3 to record videos when triggered by Wyze Sense
  • Bug fixes
2.15.22 (November 9, 2020)
  • Added a Wi-Fi/Bluetooth connection status to Wyze Lock
  • Bug fixes
2.14.23 (October 21, 2020)
  • Added support for syncing time to cameras in Australia and New Zealand
  • Fixed a bug preventing Wyze Band from linking to Alexa
2.14.22 (October 13, 2020)
General app:
  • Fixed Wyze Bulb and Wyze Plug setup failure issues with iOS 14 devices
  • Bug fixes
Wyze Band:
  • Added instructions for how to keep the Wyze app live in the background for Wyze Band data transmission
  • UI improvements
2.13.22 (September 16, 2020)
  • Fixed a bug that may cause a camera to show a solid, yellow light after an upgrade
2.13.21 (September 9, 2020)
General App:
Wyze Sense:
Wyze Scale:
Wyze Band:
2.12.51 (August 20, 2020)
  • Fixed a bug that prevented some users from logging in after logging out of the Wyze app
2.12.50 (August 17, 2020)
General App:
Wyze Cam Outdoor:
2.12.31 (August 4, 2020)
  • Fixed a Wyze Band connection bug
2.12.30 (July 29, 2020)
General App:
  • Added the new service "Cam Plus". Now you can use Person Detection with Complete Motion Capture!
Wyze Bulb:
Wyze Band:
Wyze Scale:
Wyze Lock:
2.11.41 (June 10, 2020)
  • Bug fixes
Please note that app reviews are taking longer during this time. If you do not see the update now, you should receive it in the next week or so.
  • Bug fixes
  • Bug fixes
2.9.58 (April 7, 2020)
  • Added support for Apple Health for Wyze Scale
  • Bug fixes
2.9.56 (March 31, 2020)
  • Bug fixes
2.9.24 (March 10, 2020)
  • Fixed a Daylight Savings Time bug that removed March 8 from Event list
2.9.23 (March 9, 2020)
  • Other bug fixes
  • Added support for our Cloud AI Person Detection beta. This will become available to a portion of customers and we will add people as we can while balancing the server load. If you would like to sign up for the waitlist, please fill out this form .
2.8.20 (January 27, 2020)
Pre-2020
iOS App Pre-2020
2.7.29 (December 17, 2019)
2.6.62
  • Added Complete Motion Capture (learn more at http://services.wyze.com )
  • Bug fixes
The first version was 2.6.61 but we put out another version because we needed to switch a URL from the beta server to production. Sorry for the inconvenience!
2.5.53
  • Added location permission pop up for IOS 13
2.5.45
  • Improved experience for sharing and managing shared devices
2.4.73
  • Fixed a bug causing an issue in Shop.
2.4.65
2.4.30
  • Fixed an issue that may cause unexpected logout
2.3.69
  • Fixed a bug causing the live stream to lose audio after reconnecting
2.3.25
2.2.40
2.1.32
2.1.21
  • Bug fixes
2.0.21
  • Fixed an issue where Event Videos were showing MAC addresses as camera name
  • Fixed the Events tab that was showing MAC addresses as camera name
  • Fixed a bug that two cameras from the same account sometimes mixed up Event Videos
  • Fixed a bug where watching Discover videos may cause the app to crash
  • Improved the "Forgot Password" experience
2.0.18
  • Brand new user experience for Home page (renamed from Devices page)
  • Brand new user experience for Events page (renamed from Notifications page)
  • New Discover section featuring community video content
  • New Shop section for in-app Wyze product purchase
  • Allow turning on/off notifications per camera
  • Added 'Device Sharing' in Account page Added 'Order History' in Account page
  • Updated 'Help & Feedback' user experience
  • Bug fixes
1.5.52
  • Fixed a bug that the wrong message is displayed in creating a time-lapse video
1.5.51
  • Fixed a bug that caused app crashes at splash screen on some iOS versions (10.3.3, 9.5.3, 9.3.5)
1.5.50
  • Added Wi-Fi signal strength in Device Info
  • Changed that if the camera status is changed by one user, the camera status for all users with access will be updated Fixed an issue that iOS app will crash for extended use.
1.4.48
  • Fixed an issue that WiFi change to LTE lost camera connection (Only for iOS app)
1.3.152
  • Fixed a crash when disconnecting a camera
1.3.150
1.3.134
  • Fixed an issue that caused app crashes when live streaming
  • Alert notifications now take the user directly to the videos instead of the alert video list
  • Added clear cache option
  • Remember user’s last alert schedule setting that is not all day
  • Some UI changes
  • Other bug fixes
1.3.116
  • Device sorting
1.2.84
  • Updated Daylight Savings Time handling for shared cameras
1.2.82
  • Bug fixes
1.2.72
  • App update for Wyze Cam v2
  • Reduced video lag for older iOS devices
  • Bug fixes
1.2.60
  • Support microSD card format
  • Provide option to turn on/off timestamp watermark in video frame
  • Multiple phones/tablets logged in during past 7 days using the same Wyze account will all receive alert notifications. (In V1.0 and V1.1 only one device is notified.)
  • Wyze app audio output to Bluetooth speaker
  • Bug fixes
Wyze Firmware
Learn more about how to update a device's firmware by clicking here.
Cameras
Wyze Bulb Cam Firmware
21.1.7.1256 (September 21, 2026)
  • Improved insect detection filtering.
  • Fixed an image flickering issue.
  • Improved connection stability.
  • Improved Wi-Fi setup experience.
  • Improved microSD card stability.
Note: This firmware will be gradually released over the next few weeks.
21.1.6.1161 (July 30, 2026)
  • Security improvements.
21.1.6.1117 (February 10, 2026)
  • Fixed a bug that caused event recording outside the detection zone.
  • Fixed a bug that caused the device Wi-Fi setup to fail.
  • Image quality improvements.
  • Fixed a bug that caused the device to go offline.
21.1.5.1061 (November 20, 2025)
  • Improved IoT connection stability
  • Improved event uploading stability
21.1.3.0897 (September 17, 2025)
  • Fixed bugs to increase future firmware update success rate.
21.1.3.0849 (August 18, 2025)
  • Optimized color Night Vision effects by reducing smear
  • Optimized 2-way audio performance by reducing wind noise
  • Optimized RAM usage to reduce reboot risk
  • Security updates
21.1.2.0791 (June 18, 2025)
  • Improved event uploading performance & success rate
  • Fixed a bug that caused some events to not be recorded
  • Added a backup 12s event uploading mechanism when there is an extremely weak connection.
21.1.2.0748 (June 6, 2025)
  • Fixed an issue that caused no Event recording.
  • Fixed an issue that caused an error for motion-activated light settings.
  • Optimized connectivity performance when turning the light on/off while live streaming.
  • Fixed an issue that made accessory bulbs unable to be paired.
Wyze Accessory Bulb Firmware
22.1.1.62 (March 11, 2026)
  • Added support for Breathing Light effect.
Wyze Battery Video Doorbell Firmware
1.0.0.2083 (February 10, 2026)
  • Improved connectivity stability and resolved an issue that could cause cloud video uploads to fail.
  • Updated to the latest camera SDK version to improve the connectivity quality and resolved the issue that app settings could not be saved.
  • Fixed the issue where unexpected battery drain of the SoC could prevent the MCU from reinitializing the SoC, leading to a device hang.
  • Other bug fixes.
Note: This is a gradual release over the next few weeks.
1.0.0.1939 (December 17, 2025)
  • Added a retry mechanism for device IoT Spec reporting to improve reporting success rate in unstable network conditions.
  • Fixed audio issues during playback.
  • Improved connection success rate.
  • Bug fixes.
Wyze Duo Cam Doorbell Firmware
1.0.24.37 (July 10, 2025)
  • Added information to log file.
  • Optimized false alarm issues for CO & smoke detection.
  • Resolved a rare issue where missing upgrade files could cause the device to freeze after an update.
1.0.24.29 (May 9, 2025)
  • Optimized the handling of TCP disconnections and Wi-Fi dropouts
  • Adjusted light sensor threshold for night vision mode
  • Added functionality to send an AC disconnect message to the MCU during streaming, IR-CUT switching, audio prompts, and device reboots
  • Added support for storage chip EN25QX256A compatibility
1.0.24.25 (March 27, 2025)
  • Improved event thumbnail clarity for free-tier users
  • Optimized PIR trigger algorithm to reduce false activations
  • Fixed inaccurate Wi-Fi signal strength display during setup
  • Enhanced motion filtering algorithm to minimize false alerts
1.0.24.23 (February 27, 2025)
  • Added support for automatically adjusting resolution when streaming in Wyze Web View
  • Fixed an issue where the status light displayed incorrectly after an unexpected reboot in AC mode
1.0.24.21 (January 23, 2025)
  • Updated Edge AI
  • Added PIR trigger validation in AC-mode to reduce false recordings and alerts
  • Optimized wake-up logic
  • Improved motion filtering algorithm to avoid false detections caused by color changes and device sleep transitions
  • Fixed an issue causing partial video artifacts in cloud recordings
  • Optimized pre-sleep process
  • Added support for resolution switching during live streaming via the web interface
1.0.24.11 (December 11, 2024)
  • Fixed an issue that caused an inaccurate indicator light after recovering from a network disconnection
  • Fixed an issue that caused the device to enter standby mode when the battery level dropped below 15%
  • Fixed an issue where pressing the doorbell to wake the device caused the system to crash and restart triggering the doorbell sound again
  • Resolved irregular sleep and wake cycles when the cooldown time was set to a non-zero value
  • Improved the read and write stability of the microSD card
  • Enhanced the stability of the microSD card recordings
  • Fixed an issue where microSD card ejection errors caused the automatic recording mode to be turned off
  • Adjusted the low-battery notification interval to once every 48 hours
  • Fixed an issue causing frequent crashes that led to multiple 5-minute event recordings
1.0.24.3 (November 20, 2024)
  • Improved intercom functionality between doorbell and Alexa
  • Fixed an issue where devices connected to low-voltage AC would automatically wake up after entering sleep mode
  • Optimized event recordings
  • Enhanced Wi-Fi connection
  • Adjusted silent upgrade detection to enter sleep mode within 10 seconds
  • Changed USB charging behavior so the device will enter sleep mode
  • Optimized motion bounding boxes
  • Fixed issues with setting and saving motion detection areas
  • Improved PIR sensitivity settings
  • Fixed issues relating to microSD card functionality
  • Bug fixes
Wyze Wi-Fi Chime Firmware
1.0.0.43 (August 20, 2025)
  • Default volume adjusted to level 5.
  • Increased the number of cloud command records to 30.
  • Set the maximum number of OTA retry attempts to 10.
1.0.0.42 (December 18, 2024)
  • Updated the “Setup Complete” voice prompt
  • Updated the “Ready to Connect” prompt
  • Fixed an issue where incorrect Wi-Fi passwords required re-entry but would not reconnect
  • Optimized memory usage
  • Adjusted indicator light behavior to blink red and blue after 30 seconds of IoT offline status
  • Increased the number of binding attempts
  • Improved the binding process
  • Bug fixes
Wyze Video Doorbell Pro Firmware
1.0.73 (March 1, 2023)
  • Added support for unlocking Wyze Lock Bolt from the Wyze Video Doorbell Pro live stream
1.0.68 (July 25, 2022)
  • Fixed an AC power supply status bug
1.0.66 (June 13, 2022)
  • Fixed a time zone bug that caused some regions to be set an hour ahead
1.0.64 (March 30, 2022)
  • Added support for default Quick Responses
  • Added support for motion detection zones
  • Increased detection sensitivity to 5 levels
  • The doorbell will now sleep if the live stream is left on for more than 20 minutes when using the battery
  • Optimized Event uploading logic
1.0.62 (February 23, 2022)
  • Audio from both sides of the conversation will be recorded instead of only the doorbell side
  • Improved echo cancellation to reduce noise when using 2-way audio
1.0.60 (February 14, 2022)
  • Ringing the doorbell is no longer included in motion detection cooldown
  • The default motion detection sensitivity for newly paired doorbells is now set to medium
  • Fixed a bug that caused some Events to fail uploading
  • Fixed a bug that kept the doorbell constantly active
1.0.58 (January 4, 2022)
  • Added more tones
  • Improved Event triggers/span
  • Fixed a battery indicator bug
Wyze Video Doorbell v2 Firmware
4.51.3.6791 (June 9, 2026)
  • Bug fixes
4.51.3.4992 (December 8, 2025)
  • Added Motion Warning support for Free Users
4.51.2.4190 (September 15, 2025)
  • Improved the Animated Thumbnail feature
4.51.2.3419 (May 7, 2025)
  • Security Update Wyze VerifiedView: enhances security by embedding user-authenticated signatures at the media source, adding an additional layer of security to event videos and live stream.
4.51.2.1041 (September 10, 2024)
  • Fixed a bug that caused the device to not reconnect to Wi-Fi
4.51.2.0578 (July 29, 2024)
8/1/2024 Note: This firmware has been paused while we make a cloud change
8/8/2024 Note: This firmware has been released again
4.51.2.0379 (July 16, 2024)
  • Fixed a bug that caused events to not be recorded
  • Fixed a bug that caused events to not have AI tags
  • Bug fixes
4.51.1.9807 (May 13, 2024)
  • Fixed a bug that caused notifications to stop
4.51.1.9341 (April 8, 2024)
  • Added ability to turn off sound made by the doorbell when pressed (Note: Requires Wyze app 2.50 or higher to display the option)
  • Added option for Wide Dynamic Range, to optimize the image quality and help prevent over-exposed images (Note: Requires Wyze app 2.50 or higher to display the option)
  • Optimized the system to reduce the possibility of forced restarts
4.51.1.8444 (January 24, 2024)
You need to update the app to 2.48 to receive this firmware update
App versions lower than 2.48 can't connect to this firmware due to the app and firmware security improvements
4.51.1.7518 (December 6, 2023)
  • Fixed the doorbell press 5-minute recording and notification cooldown problem for people not using Cam Plus
  • Optimized the Wi-Fi reconnecting mechanism to improve connectivity
  • Fixed a detection zone saving bug
4.51.1.7270 (November 3, 2023)
Wyze Video Doorbell v1 Firmware
4.25.1.333 (January 24, 2024)
4.25.1.316 (November 2, 2023)
4.25.1.314 (November 3, 2022)
  • Improved live stream connectivity
  • Optimized CPU usage
  • Bug fixes
4.25.1.060 (April 27, 2022)
  • Fixed a bug that caused the live stream to get stuck at 3/3
4.25.1.060 includes all the following updates from the previously halted version 4.25.1.042
  • Added support for Alexa and Google Assistant integration
  • Fixed a timestamp issue that caused persisting Error 06 on Wyze Video Doorbell Event videos
  • Fixed a bug that caused inaccurate offline statuses
  • Fixed a video rotation issue in Wyze Home Monitoring
  • Fixed a bug that prevented night vision changes
  • Fixed a bug that displayed incorrect chime firmware versions in Device Info
  • Fixed a bug that prompted updating when using the most recent update
  • Fixed a bug that prevented future setup after a Wi-Fi disconnection during pairing
Update 9/21/22: We are pausing this firmware again while we continue to work on the 3/3 live stream loading issue. Thank you for your patience.
Update 7/28/22: This firmware is being opened to the public again after review.
Note: This firmware is halted while we look into the root cause of the live stream getting stuck at 3/3 issue.
4.25.1.042 (March 30, 2022)
Note: We are pausing this firmware while we look into the cause of reports of longer loading times for live streams or connections failing at step 3/3. We apologize to anyone impacted by this issue.
4.25.0.313 (December 20, 2021)
  • Improved the night vision auto-switch mechanism
  • Fixed an IR manual control bug
  • Fixed an issue that could cause the doorbell to overheat
  • Fixed the “QR Code Incorrect” after the doorbell is reset bug
4.25.0.244 (May 12, 2021)
  • Added the Quick Replies function (2.20 app version required to trigger the voice prompts)
  • Fixed a bug that caused the white LED to turn off before Event recording completes
  • Fixed a cloud issue that caused devices to keep rebooting when the status light was solid blue
  • Fixed a noise issue while using night vision
  • Improved the QR scan performance when there is a strong backlight
4.25.0.233 (March 8, 2021)
  • Added support for a customized Motion Detection Zone
  • Added a watermark for Cam Plus Events
  • Added support for automatically changing time zones for DST
  • Improved consistency between the day and night mode views
  • Fixed a bug that prevented the audio on/off button from working
4.25.0.222 (January 28, 2021)
  • Initial release firmware
Wyze Battery Cam Pro Firmware
1.4.5.6553 (August 24, 2026)
  • Fixed a bug that caused face trigger automations to not execute properly.
1.4.4.5013 (September 8, 2025)
  • Added support for Bird Detection
  • Added support for Animated Thumbnails
  • Bug fixes
1.4.3.4543 (May 28, 2025)
1.4.2.3615 (January 15, 2025)
  • Increased daytime bitrate from 15 to 20 FPS
  • Added support for spotlight schedule
  • Improved edge AI performance
  • Improved image quality
  • Improved local microSD card recording
  • Updated MTU (Maximum Transmission Unit) to 1460
1.4.1.2289 (May 23, 2024)
  • Fixed an issue that caused no event videos for Cam Plus Unlimited users
1.4.1.2288 (February 6, 2024)
  • Added support for Smart Detection Events in Event Recording (requires Wyze app 2.49 and above)
  • Added support for turning on/off the spotlight from sunset to sunrise when motion is detected (requires Wyze app 2.49 and above)
  • Fixed a bug that caused battery drop (requires Wyze app 2.49 and above)
1.3.21.2031 (November 13, 2023)
  • Fixed a bug that caused the camera to trigger a false motion alarm between midnight and 1 AM
  • Fixed a bug that caused the camera livestream to disconnect when using continuous local recording for an extended period of time
1.3.20.1993 (October 23, 2023)
  • Added support for local microSD card recording on Wyze Battery Cam Pro
  • Improved microSD card logs
  • Fixed a bug that turned on the spotlight at midnight when the motion detection zone was turned on
  • Fixed a bug that caused Wyze Battery Cam Pro to sometimes go offline briefly after changing camera settings
1.3.19.1786 (September 14, 2023)
  • Modified the Detection Zone default setting so none of the screen is selected when it is first turned on
  • Improved the yellow-ish image quality (IQ)
  • Optimized Cam Plus video ending logic so that the camera captures whole motion events
  • Fixed the Cam Plus 06 failure to fetch video from the cloud error
  • Fixed abnormal recording failure due to incorrect Cam Plus status
  • Bug Fixes
Wyze Cam Outdoor v2 Firmware
4.48.4.450 (July 15, 2025)
  • Fixed an issue that prevented scheduled recordings from being deleted in the app.
4.48.4.427 (November 6, 2023)
4.48.4.418 (January 4, 2023)
  • Fixed a bug that prevented the rotate image 180 degrees setting from sticking
4.48.4.394 (December 7, 2022)
  • Added support for microSD cards formatted in exFAT
  • Bug fixes
12/8/22 Note: This firmware is halted while we look into reports of the rotate 180 degrees setting needing to be reapplied every time the user enters the live stream page.
4.48.4.278 (September 12, 2022)
  • Fixed a bug that caused microSD card recording to fail when allowing time zones offset by half an hour
4.48.4.140 (June 29, 2022)
  • Added support for time zones offset by half an hour
  • Fixed a night vision issue
Note: This firmware is halted because the support for offset time zones caused microSD card recording failure. We apologize for the issue and are working to resolve it.
4.48.4.124 (March 23, 2022)
  • Fixed an issue that caused delays when loading live stream video
Wyze Cam Outdoor v1 Firmware
4.17.4.450 (September 15, 2025)
4.17.4.427 (November 6, 2023)
4.17.4.418 (January 4, 2023)
4.17.4.394 (December 7, 2022)
  • Added support for exFAT microSD card formats
  • Bug fixes
4.17.4.278 (September 12, 2022)
4.17.4.140 (June 29, 2022)
4.17.4.124 (March 23, 2022)
4.17.3.93 (February 16, 2022)
  • Fixed a bug that caused Events with night vision turned on to speed up
  • Fixed a bug that caused faster battery drain when using Cam Plus
4.17.2.40 (December 20, 2021)
  • Added support for Wyze Solar Panel
4.17.1.290 (November 17, 2021)
  • Fixed a bug that prevented Cam Plus Events from being triggered or tagged correctly
4.17.1.287 (October 11, 2021)
  • Fixed an issue that caused Wyze Cam Outdoor to not record Motion Events when Cam Plus is enabled
  • Fixed an issue that caused battery drain for Wyze Cam Outdoor
4.17.1.247 (September 8, 2021)
  • Fixed a bug that caused the Base Station to keep flashing blue after changing the connection method
Note: This firmware is halted while we look into reports of a solid, yellow light on the Base Station after updating. If you have experienced this, please reach out to Wyze Customer Support.
4.17.1.185 (August 9, 2021)
  • Fixed a Base Station bug that prevented Event videos from being received properly if sent from multiple cameras at the same time
4.17.1.170 (July 14, 2021)
  • Fixed a bug that caused an incorrect battery usage status
4.17.1.123 (June 14, 2021)
  • Added a Battery Usage Summary in Device Info
  • Adjusted the image sensitivity so that it’s easier to trigger motion when the sensitivity is set to low (around 10)
  • Removed the push notification when the camera is fully charged to support future products
  • Disabled the DHCP server while the Base Station is not pairing or in Travel Mode
4.17.1.52 (April 19, 2021)
  • Bug Fixes
4.17.1.35 (March 9, 2021)
  • Added support for recording Cam Plus Events while viewing the Wyze Cam Outdoor live stream
4.17.1.027 (February 10, 2021)
  • Fixed a bug that caused Cam Plus Events to not detect people properly
  • Fixed a bug that caused accelerated battery drain with weak WiFi signal
4.17.1.019 (January 26, 2021)
  • Added support for a software motion detection zone
  • Added a Record Sound toggle
  • Fixed a bug causing error code 06 and 07
Note: Firmware file removed due to critical bugs. We are working on resolving them and will send out new versions when they're ready. Sorry for the trouble!
4.17.1.001 (January 5, 2021)
  • Hid the Base Station SSID
  • Added support for motion-only scheduled local recordings
4.17.0.186 (December 2, 2020)
  • Fixed a bug that showed the wrong duration for Cam Plus videos
  • Bug fixes
4.17.0.183 (November 3, 2020)
  • Fixed a connectivity bug caused by incompatible firmware
  • Fixed an bug that occasionally caused the firmware update to fail
  • Fixed a bug that caused the Wyze Cam Outdoor to stay connected when disconnected from WiFi
  • Fixed a bug that the prevented the status light from turning solid red when the camera was turned off and fully charged
  • Known Issues:
  • Missing Event thumbnails when Person Detection is turned off (this is a cloud issue and will be resolved later)
4.17.0.160 (October 29, 2020)
  • Fixed a bug preventing live stream connection for newer Wyze Cam Outdoor cameras
Note: This firmware version was pushed to devices that were affected. It was not available to all Wyze Cam Outdoor devices.
4.17.0.159 (September 9, 2020)
  • Added push notifications when the Wyze Cam Outdoor is full charged
  • Added push notifications when local microSD card recordings are complete
  • Fixed bugs that prevented Event videos from triggering properly
  • Fixed a delayed push notification issue
  • Added limited logs when the camera doesn't have a microSD card
  • Fixed a Travel Mode voice prompt bug
4.17.0.146 (July 29, 2020)
  • Added motion detection logic besides PIR when motion Events are triggered
  • Fixed an issue that caused night vision to turn on and off repeatedly in some low-light situations
  • Changed file directory names for microSD card recordings
  • Fixed a scheduled recording download bug
  • Fixed a bug that prevented retrieval of local recording information
  • Bug fixes
Wyze Cam Outdoor Base Station Firmware
  • Security Improvements
  • Fixed a bug that prevented Wyze Cam Outdoor cooldown time from being set to No Cooldown
4.16.4.523 (January 24, 2024)
4.16.4.512 (November 6, 2023)
4.16.4.496 (October 19, 2023)
  • Added support for user-controlled automatic updates
4.16.4.452 (December 7, 2022)
  • Bug fixes
12/12/22 Note: This firmware is being re-opened because the bug preventing the settings from sticking is found only on the camera firmware. We have a beta build that addresses the camera firmware going out to testers this week.
4.16.3.117 (April 25, 2022)
  • Fixed an issue that prevented reconnecting to the live stream after offline status
Update 5/11/22: The issue with this firmware was related to using previous app versions. We are now releasing this firmware again. Please make sure you are using Android app version 2.30.1.141 or iOS app version 2.30.1.10 before updating to Wyze Cam Outdoor Base Station firmware 4.16.3.117.
Note: This firmware is halted because of reports of a solid yellow light on the Base Station after updating. If you have experienced this, please reach out to Wyze Customer Support for assistance.
4.16.2.66 (January 18, 2022)
Note: After investigation, we are re-opening access to this firmware. Thank you for your patience while we looked into the reported issues
Note: We're sorry, folks. Base Station version 4.16.2.66 is halted while we investigate reports of Base Stations not working after the update. If this has happened to you, please reach out to us through https://support.wyze.com
Note: This is the second update in a set of two. It is important to update to version 4.16.2.45 first. If you updated to 4.16.2.66 previously, no further action is needed
4.16.2.45 (January 18, 2022)
Note: This is the first update in a set of two. After updating to this version, please update to 4.16.2.66. If you have previously updated to 4.16.2.66, do not firmware flash back to this version.
4.16.2.66 (December 20, 2021)
Note: Once your Base Station is updated to 4.16.2.66, flashing the firmware to an earlier version will prevent the Base Station from functioning. Because of this, previous Base Station firmware links have been removed.
4.16.2.37 (November 17, 2021)
  • Fixed a bug that caused rapid battery drain for the camera
4.16.2.26 (October 11, 2021)
  • Fixed an issue that prevented the Base Station from connecting to WiFi with a space in the WiFi SSID
  • Fixed an issue that caused the Base Station to show a flashing blue light
  • Fixed a bug preventing Cam Plus from detecting pets or packages on Wyze Cam Outdoor
4.16.2.16 (August 9, 2021)
4.16.2.12 (July 14, 2021)
4.16.2.7 (June 14, 2021)
4.16.1.22 (April 19, 2021)
  • Bug Fixes
4.16.1.14 (March 9, 2021)
  • Fixed a bug that caused Wyze Cam Outdoor to go offline
4.16.1.13 (February 24, 2021)
  • Added support for automatically updating time zones for DST
4.16.1.8 (February 8, 2021)
  • Fixed a bug that prevented motion detection from working
4.16.1.7 (January 26, 2021)
4.16.0.200 (January 5, 2021)
4.16.0.190 (December 2, 2020)
  • Bug fixes
4.16.0.187 (November 3, 2020)
  • Added support for Cam Plus
Known Issues:
4.16.0.169(October 29, 2020)
4.16.0.168 (September 9, 2020)
4.16.0.158 (August 19, 2020)
  • Fixed a pairing issue involving conflicting IP addresses
4.16.0.155 (July 29, 2020)
  • Fixed a bug with IFTTT that caused an incorrect motion detection status
  • Changed file directory names for downloads, Event videos, and thumbnails
  • Bug fixes
Wyze Indoor Cam Pan Firmware
2.1.0.133 (October 12, 2026)
  • Fixed setup failures caused by WPA3 compatibility issues with certain routers.
  • Fixed setup failures with certain routers.
  • Improved Bluetooth and Wi-Fi connection handling during setup.
  • Fixed setup failures caused by delayed status synchronization.
  • Fixed an issue that could cause occasional restarts when viewing through the web interface.
Wyze Solar Cam Pan Firmware
2.0.0.2130 (July 20, 2026)
  • Improved AI smart detection accuracy.
2.0.0.2083 (February 3, 2026)
  • Other bug fixes.
2.0.0.1939 (November 21, 2025)
  • Updated pan-tilt control and return logic:
    • If the user manually adjusts the pan-tilt during tracking, the camera will hold that position and pause tracking for 10 seconds.
    • After tracking ends, if the user is still in live view, the camera returns to the last manually controlled position.
  • Other bug fixes.
Wyze Duo Cam Pan Firmware
1.0.0.179 (July 8, 2026)
  • Added Smart Track support, with the option to track people and vehicles only.
1.0.0.167 (November 3, 2025)
  • Updated Home Waypoint (HWP) logic — no Home Waypoint is set by default (requires App version 3.8.5 or later).
  • Improved return behavior during Pan Scan — the camera now correctly returns to the Home Waypoint after motion tracking is triggered.
  • Improved calibration logic — if a Home Waypoint is set, the camera will return to it after calibration.
  • Optimized Wi-Fi connection strategy — when multiple networks share the same SSID, the camera will now prefer the one with stronger signal.
  • Fixed a rare issue where livestream loading could become stuck.
1.0.0.163 (September 24, 2025)
  • Added the ability to switch between the main and sub camera views in Webview PiP mode.
  • Optimized the spotlight activation threshold.
  • Improved the image clarity during the spotlight activation at night (reduced overexposure).
  • Removed the 2-minute delay between Pan Scan cycles.
  • Improved color consistency between the two lenses.
  • Increased the return-to-home speed after tracking ends.
  • Fixed a rare issue where the spotlight could turn on unexpectedly during power on or off.
Wyze Cam Pan v4 Firmware
4.70.7.4408 (October 15, 2026)
  • Improved Motion Tracking stability and camera positioning after tracking.
  • Improved Timelapse download speed and reliability.
  • Improved Detection Zone accuracy.
  • Improved detection box display.
  • Improved Wi-Fi reconnection speed when switching networks.
  • Fixed an issue with Timelapse scheduling in certain time zones.
Note: This is a gradual rollout over the next few weeks. If you do not see it yet you should soon.
4.70.6.4312 (September 23, 2026)
  • Fixed an issue with Wi-Fi reconnection.
  • Fixed a rare issue where motion tracking and notifications could stop working.
4.70.5.4200 (August 26, 2026)
  • Improved device reliability to reduce the risk of device failure under unstable power conditions.
4.70.3.4024 (July 21, 2026)
  • Fixed an issue where the camera could occasionally fail to return to its default position.
  • Improved compatibility with certain legacy Wi-Fi routers for more reliable connectivity.
4.70.3.3930 (June 24, 2026)
  • Fixed a bug that could cause the camera to drift.
  • Improved camera and motor movement accuracy.
  • Improved tracking smoothness with optimized speed and compensation behavior.
  • Improved setup success rate and connection reliability.
  • Improved Wi-Fi switching stability.
  • Fixed an issue with time-lapse recording.
  • Improved motion zone detection accuracy.
Note 6/30/2026: This firmware has been paused while we investigate connection issues.
4.70.2.3661 (May 21, 2026)
  • Optimized motor calibration strategy.
  • Added the ability to change WiFi network without re-setup.
  • Improved event video uploading reliability.
  • Improved WiFi connectivity in mesh network environments.
  • Improved video quality with optimized encoding and full-range color.
  • Improved live streaming stability under low-bandwidth conditions.
  • Fixed a Bluetooth discovery issue during device setup.
4.70.1.3311 (February 12, 2026)
  • Improved live streaming stability with optimizations across several system components.
  • Fixed an issue where Pan Scan could interrupt Smart Tracking.
  • Fixed an issue where Detection Zone settings could affect event notifications and tracking performance.
  • Improved tracking accuracy and responsiveness.
4.70.0.3005 (January 6, 2026)
  • Added the new Timelapse feature.
  • Improved livestream lagging issues.
  • Improved connection stability and reduced offline occurrences
  • Improved tracking, calibration, and their interaction logic for smoother pan/tilt behavior.
  • Fixed an issue where the camera tilted downward after firmware update on devices without Waypoints set.
  • Enhanced horizontal pan accuracy to reduce camera view drift
  • Fixed abnormal tagging box display when enabling Motion Tagging for the first time
  • Fixed an issue where AI event tags may be missing in Event View
  • Optimized speaker latency during two-way audio.
  • Optimized CPU usage for smoother performance
4.70.0.2714 (November 21, 2025)
  • Improved connection stability and reduced offline occurrences.
  • Enhanced horizontal pan accuracy to reduce camera view drift.
  • Fixed abnormal tagging box display when enabling Motion Tagging for the first time.
  • Fixed an issue where AI event tags may be missing in Event View.
  • Optimized CPU usage for smoother performance.
Note 1/6/2026: This firmware has been paused.
4.70.0.2595 (October 14, 2025)
  • Improved device offline stability.
  • Fixed an issue where bounding boxes were still drawn for stationary objects when Track Motion was turned off.
  • Optimized Smart Tracking priority logic.
  • Fixed a bug where the camera faced downward after firmware upgrade.
4.70.0.2507 (October 3, 2025)
  • Optimized Home Waypoint logic: if manual pan/tilt is detected, the camera will only return to the Home Waypoint after the current live session ends.
  • Removed Home Waypoint as a required setting. This change will take effect with the App 3.8 release.
  • Optimized device memory usage.
4.70.0.2415 (September 22, 2025)
  • Fixed a device offline issue.
  • Fixed an issue where shared users could not watch live streams.
  • Fixed an issue with tracking stationary vehicles and optimized algorithm memory usage.
  • Fixed a potential crash issue.
  • Optimized microSD card playback stuttering issue.
  • Optimized image quality and updated image quality.
  • Optimized “all motion” bounding box issue.
Wyze Cam Pan v3 Firmware
4.50.17.25 (September 23, 2026)
  • Fixed a bug that could cause microSD card format failure.
Note: We are doing a gradual release for this firmware over the next few weeks. If you do not have this firmware version yet, don't worry! You'll receive it later.
4.50.17.19 (September 14, 2026)
  • Fixed an issue that introduced more noise in audio.
  • Event upload stability improvements.
  • Network stability improvements.
4.50.17.10 (August 11, 2026)
  • Network connectivity improvements
Note: This release has been paused. A new version will be released soon.
4.50.16.7064 (July 15, 2026)
  • Added firmware support for continuous video recording to the cloud.
  • Bug fixes.
4.50.16.6242 (March 23, 2026)
  • Fixed an issue that caused failed or slow live stream connections.
  • Fixed an issue that caused failed microSD card detection.
Note: Updating to app version 3.11 is required for a complete fix. If either component remains outdated, the issue may persist.
4.50.16.5654 (February 2, 2026)
  • Added RTSP support (You will need to update the app to version 3.9 or above).
  • Added ability to change Wi-Fi without device reset (You will need to update the app to version 3.9 or above).
  • Improved facial detection resolution.
  • IoT connection stability improvements.
  • Bug fixes
Note: You will need to update the app to version 3.8.5 or above to receive this firmware update. App versions lower than 3.8.5 can’t connect to this firmware due to security improvements in both the app and the firmware.
4.50.15.5336 (December 3, 2025)
Note: This firmware will be released gradually over the next few weeks.
4.50.15.4800 (October 9, 2025)
4.50.14.3339 (April 29, 2025)
4.50.5.1318 (October 16, 2024)
  • Improved Wi-Fi reconnection logic
  • Bug fixes
4.50.5.0587 (July 29, 2024)
8/7/2024 Note: This firmware has been released again
4.50.4.9222 (April 1, 2024)
  • Added support for Camera as Chime function
4.50.4.8409 (January 23, 2024)
  • You need to update the app to 2.48 to receive this firmware update
  • App versions lower than 2.48 can't connect to this firmware due to the app and firmware security improvements
Note: This is a gradual release, releasing to 20% on January 23
4.50.4.7252 (November 2, 2023)
4.50.4.4767 (August 17, 2023)
  • Fixed an issue that caused failure when usin Continuous Recording to a microSD card
  • Fixed a bug that prevented detection and recording of Events
  • Fixed a position reset failure bug that occurred after the camera was turned on
4.50.3.4240 (April 24, 2023)
  • Improved Wi-Fi connection stability
  • Fixed an issue that caused dropped frames
  • Fixed a bug that prevented recording Events to a microSD card
4.50.2.3762 (February 20, 2023)
Note: This is releasing to 10% of customers on February 20th. We'll release to more customers over the following 3 weeks. If you don't see the update now, don't worry! You'll see it later.
4.50.1.3603 (January 30, 2023)
  • Improved stability for playing Event Videos
  • Fixed a bug that displayed the wrong time zone
4.50.0.3405 (January 10, 2023)
  • Improved the Error Code 06 rate for replaying Event Videos
  • Fixed a bug that caused Pan Scan to record excessive Events
  • Fixed a bug that caused microSD card reading issues
Wyze Cam Pan v2 Firmware
4.49.17.21 (September 21, 2026)
  • Bug fixes for Continuous Video Recording
4.49.17.19 (September 14, 2026)
4.49.17.10 (August 11, 2026)
4.49.16.7064 (July 15, 2026)
  • Bug fixes.
4.49.16.6114 (March 23, 2026)
4.49.16.5654 (February 2, 2026)
  • Bug fixes.
4.49.14.3289 (May 1, 2025)
  • VerifiedView improvements
  • Improved IoT connection stability and offline self-recovery
4.49.14.3137 (April 16, 2025)
4.49.13.0653 (August 8, 2024)
  • Fixed a bug causing Motion Tracking to be automatically enabled after a firmware update
4.49.13.0416 (July 18, 2024)
  • Fixed a bug that caused incorrect LED status
  • Bug fixes
7/18/24 - Note: We are doing a gradual release for this firmware over the next few weeks. If you do not have this firmware version yet, don't worry! You'll receive it later.
4.49.11.8391 (January 16, 2024)
  • App versions lower than 2.48 can’t connect to this firmware due to the app and firmware security improvements
4.49.11.7095 (October 31, 2023)
4.49.3.7177 (October 31, 2023)
  • Reduced the likelihood of update failure from the previous version
4.49.3.4054 (March 22, 2023)
  • Improved Event Video recording stability
  • Improved Internet connection logic and connection recovery
  • Fixed a bug that caused Cam Plus Lite Events to not play due to Error 3001
  • Fixed an issue that caused Event Videos to lose frames
  • Fixed a bug that affected Internet connection when connected to open Wi-Fi
  • Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.49.1.47 or below
4/3/23 - Note: We're slowing down the gradual release for this firmware while we check on some reported issues. The gradual release is expected to take longer than initially expected to accommodate this caution
3/22/23 - Note: We are doing a gradual release for this firmware over two weeks. If you do not have this firmware version yet, don't worry! You'll receive it later
4.49.3.2864 (November 2, 2022)
  • Improved Internet connection code
  • Improved IoT connectivity
  • Fixed a bug that prevented the device from reconnecting after a router reboot
  • Fixed a bug that caused an incorrect membership status after quickly switching membership
  • Fixed a bug that caused Error 3001 when viewing motion and sound Events
  • Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.49.1.47 or below.
11/10/22 - Note: This firmware is being halted to investigate an issue with event recording.
11/2/22 - Note: We are doing a gradual release for this firmware over two weeks. If you do not have this firmware version yet, don't worry! You'll receive it later
4.49.3.2705 (October 18, 2022)
  • Bug fixes
11/2/22 - Note: This firmware was replaced with 4.49.3.2864
4.49.1.47 (March 17, 2022)
4.49.1.41 (February 17, 2022)
  • Fixed Cam Plus Lite bugs
4.49.1.34 (January 26, 2022)
  • Fixed an integration bug with Wyze Home Monitoring
  • Fixed a log issue after unexpected reboot
4.49.1.25 (October 21, 2021)
  • Fixed a rebooting bug when using 360p for viewing the live stream
4.49.1.21 (September 10, 2021)
  • Stability improvements
Wyze Cam Pan v1 Firmware
4.10.9.3006 (January 16, 2024)
4.10.9.2847 (November 6, 2023)
4.10.9.2351 (September 14, 2023)
  • Fixed an Error Code 3001 bug for Cam Plus Lite Events
  • Fixed a bug that affected camera connection recovery after a cloud outage
9/14/23 - Note: This is a gradual release. If you don't see the update today, you should see it later this month.
4.10.9.1851 (February 2, 2023)
  • Improved the Event Video upload success rate<></>
4.10.9.1574 (December 7, 2022)
  • Fixed a bug that affected camera connection on Wi-Fi with a long password
  • Fixed a bug that prevented AI detection settings from syncing
4.10.9.1472 (November 2, 2022)
  • Fixed a bug that affected camera IoT connection after a cloud outage
  • Fixed a bug that caused incorrect membership status after switching between statuses
4.10.9.1433 (September 27, 2022)
  • Improved microSD card playback stability
  • Bug fixes
  • Due to the security improvement on this firmware, you will need to go through the setup process for your camera if you go back to firmware 4.9.8.1002 or below. Because of this, we are removing those firmware files from this page.
Note: We are doing a gradual release for this firmware over several weeks. If you do not have this firmware version yet, don't worry! You'll receive it later.
4.10.8.1002 (March 17, 2022)
  • AI Event bug fixes
4.10.8.860 (January 26, 2022)
  • Bug fixes
Note: This firmware is paused because some of the devices with this firmware lose AI detection. We are working on a new firmware version to resolve this issue.
4.10.8.746 (December 20, 2021)
  • Added support for microSD cards larger than 32GB
  • Improved the Cam Plus Event replay success rate
  • Improved camera stability
  • Fixed a constant reboot bug
  • Fixed a bug that prevented sound notifications when using Cam Plus
  • Fixed a bug that caused missing Events when using Cam Plus
  • Other bug fixes
Note: This release is halted while we investigate an AI bug and live streaming issue. We apologize for the inconvenience.
4.10.8.501 (November 10, 2021)
  • Bug fixes
4.10.7.1068 (September 8, 2021)
  • Bug fixes
4.10.7.798 (July 21, 2021)
  • Improved an issue that caused Cam Plus Events to skip or lose frames
  • Changed the MP4 audio format
  • Reduced the time for receiving push notifications
  • Improved sound detection sensitivity
  • Fixed a bug that caused a loud sound in Playback if sound was already enabled in the live stream
  • Added WPA3 WiFi network support
4.10.6.241 (March 9, 2021)
  • Increased 2-way audio volume for Wyze Cam v2 and Pan
  • Adjusted the motion detection sensitivity per users’ feedback
  • Improved Cam Plus Event push notification time (less strong networks may not see much change)
  • Improved the stability of time stamp syncing with the NTP server
  • Improved stability for motion detection
  • Fixed a bug that caused Event videos to lose a couple of seconds at the beginning
  • Fixed a bug causing unnecessary camera reboot
  • Other bug fixes and improvements
Note: This firmware update has been halted while we investigate the cause of an issue that may be related to this update. If we find that the update is not the cause, we will resume the rollout.
4.10.6.218 (November 18, 2020)
  • Added support for a custom motion detection zone (2.15 app required)
  • Fixed a bug that caused turned off cameras to start recording after being power cycled
  • Changed the algorithm for motion detection when a detection zone is enabled.
  • Changed the motion tracking logic when a detection zone is enabled.
Note: This firmware update is halted as we look into increased motion detection sensitivity. If you still want this update, you can flash the firmware using the file linked here.
4.10.6.199 (October 21, 2020)
  • Fixed a bug that would impact the DST time change
  • Fixed a bug that prevented syncing with GMT+13 and GMT+14 time zones
4.10.6.193 (October 5, 2020)
  • Fixed a bug that caused Wyze Cam Pans to go offline if the camera time zone is outside of GMT-8 to GMT+8
4.10.6.191 (September 30, 2020)
  • Improved the logs for error analysis
  • Fixed a bug that may increase the 'no fragment' error for Event videos
  • Fixed a bug which may cause Cam Plus devices to not record motion
  • Fixed an bug that could cause a log submission to fail
  • Fixed a reboot issue during microSD card playback
  • Fixed a reboot issue related to detection zone settings
  • Fixed a Wyze Cam Pan bug that caused over-sensitive motion detection when a Detection Zone was enabled
  • Fixed a Wyze Cam Pan bug that could trigger Events due to motor movement
  • Fixed a bug that could erase microSD card files when not using the FAT32 format
  • Other bug fixes
Note: This update was stopped and we will not be uploading the file for download due to a time zone bug fixed in 4.10.6.193.
4.10.6.156 (July 28, 2020)
  • Added support for Person Detection on CMC videos (2.12 app update required)
  • Improved CMC camera stability
  • Improved Wyze Cam performance
  • Fixed an issue which could cause Wyze Cams using CMC to reboot
  • Other bug fixes
4.10.5.111 (March 18, 2020)
  • Optimized the SD card ejection logic
  • Improved Google Nest Hub streaming
4.10.5.98 (January 27, 2020)
  • Removed XNOR person detection
  • Added support for ejecting microSD cards
  • Improvements for syncing video and audio
  • Fixed event videos making noise when camera has disabled sound recording and CMC service is being used
  • Fixed live stream disconnect issues for camera groups
  • Other bug fixes
4.10.5.94 (January 21, 2020)
  • Other bug fixes
4.10.5.34 (November 15th, 2019)
  • Added support for Complete Motion Capture, an add-on service that will record to the cloud whenever there is motion. Free trial available after the upcoming 2.6 app update
  • Bug fixes
4.10.3.169 (September 24th, 2019)
  • Added New AI model improving person detection
  • Added Security Updates
4.10.3.108 (July 8, 2019)
  • Added person detection support
  • Added support for Wyze Sense status light toggle
  • Fixed an issue that may cause time lapse file download failure
  • Fixed an issue that may cause Wyze Sense Bridges to stop working when rebooting or upgrading the camera
  • Fixed an issue that may cause Wyze Sense Bridges to remain solid yellow if the Wyze Cam Pan loses power
4.10.3.60 (May 9, 2019)
  • Fixed an issue that prevented motion from being properly detected
4.10.3.50 (April 23, 2019)
  • Integrated the latest firmware for Wyze Sense
  • Improved the security of time lapse downloading
  • Fixed the issue with no internet connection causing reboot
  • Improved the compatibility with mesh networks
  • Applied the detection zone and sensitivity settings for local recording
  • Security updates
4.10.3.40 (March 4, 2019)
  • Fixed an issue where devices rebooted due to poor network connections.
  • Fixed an issue leading to device reboot when the Wyze Cam does not have microSD card read/write permission.
  • Fixed an issue causing devices to not recognize microSD cards.
  • Fixed an issue where devices sent extra heartbeat signals to AWS.
  • Added logic to adjust the camera clock automatically for Daylight Savings Time.
  • Security updates
4.10.2.31 (January 15, 2019)
  • Minor IQ (image quality) update, which fixed some devices having yellow tint images
4.10.2.27 (December 17, 2018)
  • Added more guard check before firmware upgrade to make upgrade safer
  • Added logs for firmware upgrade to catch upgrade issues
  • Fixed an issue that cameras may not execute on/off/restart commands correctly
  • Updated solution for the ‘incorrect offline status’ issue
  • Fixed an issue that can cause cameras to upload event videos multiple times
4.10.1.40 (October 22, 2018)
  • Fixed a bug that caused Playback to play faster during the minute transition
  • Added that photos are saved on microSD card as well as the device Album
  • Fixed the yellow tint issue on Wyze Pan images
  • Other bug fixes
4.10.1.27 (September 18, 2018)
  • Added V1.5 feature support
  • Fixed a bug when the camera is off, night vision switches on/off and IR lights stay on
  • Fixed a bug when the camera is off, it still sends alerts
  • Other bug fixes
4.10.1.8 (July 11, 2018)
  • Added Alexa integration support
  • Added v1.4 App IoT feature support
  • Fixed a bug that night vision LED’s stayed on when the camera is turned off.
  • Fixed an issue when IoT status is not updated correctly
  • Bug fixes
4.10.0.223 (June 15, 2018)
  • Fixed an issue for firmware upgrade
  • No functionality change
4.10.2.222 (May 30, 2018)
  • Support all existing features for Wyze Cam v1/v2
  • New pan/tilt control support
  • New motion tracking feature
  • New Pan Scan feature
  • Enhanced 2-way audio
Wyze Window Cam Firmware
1.3.0.63 (September 14, 2026)
  • Fixed a bug that could cause device reboot.
  • Fixed a bug that caused microSD card to be unreadable.
  • Fixed a bug that caused Alexa to not play sound.
1.3.0.52 (July 8, 2026)
  • Fixed a bug that could cause microSD card recognition failure.
  • Added microSD card use guidance.
  • Added microSD card Insert/Remove Notification.
Note: Insertion/Removal Notification will only be available with App 3.16 and above.
1.3.0.48 (June 10, 2026)
  • Fixed a bug that could cause an event uploading error
1.3.0.47 (May 12, 2026)
  • Fixed a microSD card empty folder bug for Free Users
  • Fixed a firmware downloading failure issue
  • Fixed a bug that could cause detection failure
1.3.0.29 (March 4, 2026)
  • Fixed multiple bugs that may cause setup failure.
  • Improved person detection accuracy under low-light conditions.
  • Fixed bugs that may cause the MicroSD card to stop recording.
  • Daylight saving time conversion bug fixed.
  • Security updates.
1.3.0.23 (December 3, 2025)
  • Fixed a bug that caused the device to freeze.
Wyze Cam OG (2025 Version) Firmware
1.1.0.123 (September 8, 2026)
  • Improved the microSD card experience.
  • Optimized cloud storage upload logic to improve upload success rates in certain scenarios.
  • Bug fixes.
1.1.0.97 (June 26, 2025)
  • Fixed an issue that caused smart event detection tags to be missing.
  • Optimized connectivity performance while live streaming on Alexa & Google devices.
  • Fixed an issue that caused motion only events to not be filtered correctly when Smart Detection events are selected
Wyze Cam OG Firmware
1.0.98 (May 19, 2025)
1.0.84 (October 9, 2024)
  • Fixed motion tagging to only draw bounding box within motion detection zone
1.0.82 (July 19, 2024)
  • Improved connectivity with Wyze Web Portal
  • Bug fixes
1.0.80 (January 29, 2024)
  • Fixed a bug that caused the camera to reboot due to microSD card corruption
  • Improved Wyze Web Portal connectivity
  • Bug fixes
1.0.71 (November 13, 2023)
  • Improved motion detection algorithms to reduce detection of light, orbs, and rain at night
  • Bug fixes
1.0.67 (August 12, 2023)
  • Added support for granular spotlight controls including setting schedules, adjusting the light timer, and activating the spotlight based on motion or sound triggers
  • Added support for Dusk (low light) and Dark (extremely low light) conditions to Night Vision Modes
  • Added support for Motion Warning under Camera Settings > Detection Settings > Motion Warning. Note: This requires Cam Plus for Person Detection
  • Added support for Smart Detection Events to only detect and record motion triggered by people, pets, vehicles, or packages. Note: This requires Cam Plus for object detection
  • Adjusted Night Vision to maintain color in darker environments
  • Bug fixes
1.0.63 (March 22, 2023)
  • Fine-tuned image color accuracy
  • Fixed a compatibility issue with certain ISP that resulted in occasional Cam Plus video upload failures
  • Bug fixes
1.0.59 (February 13, 2023)
  • Improved red color and clarity in certain lighting conditions
  • Optimized night vision brightness with the IR LED turned off
  • Fixed a bug that prevented Event Videos from being downloaded if the Record Sound setting was turned off
  • Fixed a Playback freeze issue
  • Bug fixes
Wyze Cam OG Telephoto Firmware
  • Bug fixes
  • Bug fixes
1.0.67 (August 14, 2023)
  • Added support for Smart Detection Events to only detect and record motion triggered by people, pets, vehicles, or packages. Note: This requires Cam Plus for object detection/span
  • Fixed the blue color tint in for outdoor low light conditions
  • Bug fixes
Wyze Cam v4 Firmware
4.52.17.26 (September 23, 2026)
  • Fixed a bug that could cause microSD card playback audio and video mismatch.
4.52.17.19 (September 14, 2026)
4.52.9.6119 (March 23, 2026)
4.52.9.5332 (December 3, 2025)
4.52.9.4188 (September 15, 2025)
4.52.9.3415 (May 7, 2025)
4.52.9.1134 (November 1, 2024)
  • Optimized video to fix reddish tint issue
  • Fixed a bug that caused a delay when turning off the siren
  • Fixed a bug that caused an issue where the lamp socket could not be triggered after turning off sound events
  • Updated spotlight UI and removed sound trigger
4.52.8.0648 (September 4, 2024)
  • Fixed an issue where the indicator light flashes red and blue after the router loses connection
  • Updated the logo watermark
  • Fixed an issue that would return a -90 error
  • Added environment brightness judgment for the spotlight
  • Optimized audio algorithm
4.52.7.0367 (July 11, 2024)
  • Bug fixes
4.52.4.9887 (May 21, 2024)
  • Fixed a bug in the setup routine
  • Fixed a bug that limited events after Friendly Faces is activated
  • Fixed a bug keeping time from syncing after a power cycle
  • Fixed a bug that caused a forced restart when experiencing low signal strength
  • Fixed a bug that kept the spotlight from turning off
  • Fixed a bug that caused the speaker to buzz for a few seconds when powered on for the first time
  • Added more detailed log information for debugging
  • Updated the Wi-Fi driver
  • Updated the watermark logo
4.52.3.9455 (March 26, 2024)
  • Initial firmware release
Wyze Cam v3 Pro Firmware
4.58.17.21 (September 21, 2026)
  • Bug fixes for Continuous Video Recording.
4.58.17.19 (September 14, 2026)
4.58.17.10 (August 11, 2026)
4.58.16.7064 (July 15, 2026)
  • Bug fixes.
4.58.16.6797 (May 28, 2026)
Note: Please update the Wyze app to version 3.14 or later to use this feature.
4.58.16.6114 (March 23, 2026)
4.58.16.5654 (February 2, 2026)
  • Bug fixes.
4.58.14.4178 (August 18, 2025)
  • Fixed a bug that caused event frame loss
  • Fixed a bug that caused microSD card playback to not function properly
4.58.14.3289 (May 15, 2025)
4.58.13.2958 (April 3, 2025)
  • Improved live stream connection
  • Fixed a bug that may cause the device to be not responsive after a firmware update
4.58.13.2340 (March 6, 2025)
3/7/2025 - Note: We have paused this firmware while we look into a reported issue.
4.58.13.1321 (October 9, 2024)
  • Improved event video uploading success rate
  • Fixed a bug that could cause event recording to get stuck
11/29/2024 - Note: We have paused this firmware while we look into a reported issue.
4.58.13.0416 (July 18, 2024)
  • Bug fixes
4.58.11.8391 (January 16, 2024)
4.58.11.7357 (November 8, 2023)
4.58.11.7214 (November 1, 2023)
11/2/23 - Note: We are pausing this release while we check on some reported issues.
4.58.11.4679 (June 8, 2023)
  • Improved the IoT connection success rate
  • Improved the Event Video replay success rate
  • Fixed a bug that caused the spotlight to always stay on
  • Fixed a bug that prevented viewing Playback video
  • Fixed a bug that impacted WPA2 and WPA3 mixed network connections
  • Bug fixes
4.58.0.3210 (December 12, 2022)
  • Improved low light performance
  • Improved noise cancellation
  • Improved thumbnail image quality
  • Improved log recording
  • Reduced firmware size
  • Fixed a 0 second Event Video bug
  • Fixed a device connection issue
4.58.0.2905 (November 2, 2022)
  • Optimized the user experience
Wyze Cam v3 Firmware
Wyze Cam v3 Firmware Firmware
4.36.17.21 (September 21, 2026)
4.36.17.19 (September 14, 2026)
  • Fixed an issue that caused abnormal Floodlight playback speed.
4.36.17.10 (August 11, 2026)
4.36.16.7064 (July 15, 2026)
  • Bug fixes.
4.36.16.6114 (March 23, 2026)
4.36.14.3497 (May 27, 2025)
  • Firmware Metrics improvements
  • Bug fixes
4.36.14.3289 (May 1, 2025)
  • Improve IoT connection stability and offline self-recovery
4.36.14.2953 (April 3, 2025)
4.36.13.0416 (July 18, 2024)
  • Fixed a bug that caused no audio playback on Wyze Cam v3 when connected to Wyze Cam Floodlight (v1)
  • Bug fixes
4.36.11.8391 (January 16, 2024)
4.36.11.7095 (October 25, 2023)
  • Fixed a bug that prevented saving the Detection Zone
4.36.11.7071 (October 22, 2023)
4.36.11.5859 (August 30, 2023)
  • Improved log collection for IoT disconnections
  • Bug fixes
10/13/23 - Note: We are pausing this release while we check on some reported issues.?
8/30/23 - Note: This is a gradual release. If you don't receive it immediately, we expect you to receive it over the next month. Thank you!
4.36.11.4679 (July 13, 2023)
  • Fixed a bug that caused Playback video to skip the first minute every hour
  • Fixed a bug that caused Playback video to not be smooth while playing
  • Bug fixes
8/4/23 - Note: We analyzed the metrics and found a failure rate higher than what we aim for. We're going to work on a new build and release that. If any of the bug fixes in this update are important to you, please consider flashing the firmware using the link on the version number here.
7/13/23 - Note: This is a gradual release. If you don't see the update yet, you'll receive it in the upcoming weeks. Thanks for your attention!
4.36.10.7146 (October 30, 2023)
  • This firmware will only be available to devices with 4.36.10.4054 firmware
4.36.10.4054 (March 22, 2023)
  • Due to the security improvement on this firmware, you will need to go through the factory reset process for your camera if you go back to firmware 4.36.9.139 or below
4/3/23 - Note: We're slowing down the gradual release for this firmware while we check on some reported issues. The gradual release is expected to take longer than initially expected to accommodate this caution.
3/22/23 - Note: We are doing a gradual release for this firmware over two weeks. If you do not have this firmware version yet, don't worry! You'll receive it later.
4.36.10.3406 (December 15, 2022)
  • Fixed bugs that caused Events to fail uploading to the cloud
  • Fixed a bug that prevented devices from reconnecting to IoT
12/16/22 Note: Now all Wyze Cam v3s using 4.36.10.2163 or higher firmware will have access to this release. Thanks for your patience!
12/15/22 Note: This firmware is only released to cameras using the 4.36.10.2864 firmware to fix bugs introduced in that version. Cameras not using that version will not have this update available to them. Cameras using version 4.36.10.2700 will receive the firmware as a manual push from our side.
4.36.10.2864 (November 2, 2022)
  • Fixed an issue that prevented the device from reconnecting after a router reboot
  • Fixed an issue that caused devices to stop working after a firmware update
11/2/22 - Note: We are doing a gradual release for this firmware over two weeks. If you do not have this firmware version yet, don't worry! You'll receive it later.
4.36.10.2700 (October 18, 2022)
  • Bug fixes
11/2/22 - Note: This firmware was replaced with 4.36.10.2864.
4.36.9.139 (May 18, 2022)
  • Added support for garage door controller trigger duration settings
4.36.9.131 (April 25, 2022)
Wyze Cam v3:
  • Improved logs for accessory product firmware update failure
  • Adjusted the audio priority for camera features
  • Fixed an image quality bug that produced a strobing effect
  • Fixed a bug that caused a reboot after pairing Wyze Cam v3 for the first time
Wyze Lamp Socket:
  • Improved lamp socket response time
Wyze Cam Floodlight:
  • Reduced face overexposure when the floodlight is turned on
  • Modified the default lighting time to 30 seconds
  • Fixed a bug that caused false detection when viewing the live stream
4.36.8.32 (March 17, 2022)
4.36.8.26 (February 17, 2022)
4.36.8.15 (December 6, 2021)
Wyze Cam v3:
  • Improved logs
  • Bug fixes
Wyze Lamp Socket:
  • Improved sunrise/sunset schedule performance
  • Improved connection with Wyze Cam v3
  • Fixed a pairing bug when using multiple Wyze Cam v3 cameras
  • Fixed a night vision bug
  • Bug fixes
  • Adjusted the lighting threshold for when the floodlight turns on
  • Fixed a siren bug
  • Improved logs
  • Bug fixes
4.36.7.22 (November 22, 2021)
Wyze Cam v3:
  • Fixed a bug preventing Wyze Home Monitoring compatibility
  • Bug fixes
Wyze Lamp Socket:
  • Fixed a bug that prevented restart logs from generating
  • Fixed a bug preventing status updates in the Home tab
  • Fixed a bug that impacted turning on night vision after it was turned off for a long time
  • Algorithm improvements
  • Improved 2-way audio
  • Adjusted default settings
4.36.6.17 (November 3, 2021)
  • Added the ability to unpair Wyze Lamp Socket
  • Improved Wyze Lamp Socket stability
  • Fixed a siren noise bug
  • Bug fixes
4.36.3.19 (August 26, 2021)
  • Improved Spotlight recognition
  • Updated Spotlight settings
  • Added 2-way audio support for WebRTC
Note: This firmware can be flashed without flashing the 4.36.3.18 firmware first. But if you are using the standard in-app update method, you will need to update to 4.36.3.18 and then begin the update process for 4.36.3.19.
4.36.3.18 (August 26, 2021)
  • Update required for the 4.36.3.19 update to function properly
4.36.2.5 (June 14, 2021)
  • Improved logs
  • Improved memory usage
  • Improved power consumption when connected to WiFi
  • Improved system stability
4.36.1.4 (May 5, 2021)
  • Added support for turning on the spotlight when sound is detected
  • Added support for using the spotlight via Rules
  • Improved Event video uploading
  • Improved spotlight firmware stability
  • Improved the sound detection algorithm
4.36.0.280 (March 29, 2021)
  • Added microSD card status reporting to the app
  • Added support for siren control in Rules
  • Fixed a Spotlight recognition bug when the WiFi signal is weak
  • Added Spotlight debugging information to logs
  • Improved the Spotlight update process
  • Spotlight motion detection now uses the camera motion detection setting
4.36.0.252 (February 17, 2021)
  • Improved the recognition rate for microSD cards
  • Added a turn off function for microSD cards
  • Added an independent update function for the Spotlight
  • Fixed a bug when switching Spotlights
  • Fixed a Spotlight authentication failure bug
  • Fixed an excessive DNS lookup issue
4.36.0.248 (February 1, 2021)
4.36.0.228 (December 28, 2020)
  • Improved local storage stability
  • Fixed a connectivity bug that caused live streams to get stuck at 3/3
  • Fixed a bug that caused a yellow spot in the center of the video
  • Added Spotlight support
4.36.0.125 (November 15, 2020)
Wyze Cam Floodlight Pro Firmware
2.2.1.1343 (July 9, 2026)
  • Faster live view with more stable streaming.
  • Improved microSD card experience.
2.2.1.1223 (May 8, 2025)
2.2.1.1176 (January 8, 2025)
  • Fixed an issue that could cause the device to stop recording events
  • Fixed an issue that could cause microSD card recordings to not be viewable
  • Improved event uploading success rate
2.2.1.1168 (November 12, 2024)
2.2.1.1135 (March 14, 2024)
  • Improved device stability in situations where there is insufficient network bandwidth
  • Fixed an issue where the motion-activated light was not functioning due to a lack of location permission
  • Fixed an issue where the motion-activated light was not functioning properly
  • Reduced false event reports caused by flying insects or raindrops when ‘All Events’ is selected in the Event Recording setting
2.2.1.1102 (January 4, 2024)
  • Fixed an IoT offline issue
  • Fixed an Event tagging bug
2.2.1.1083 (October 31, 2023)
  • Added support for audio clip and repeat interval settings for Motion Warning (Wyze app 2.45 or later required)
  • Updated Image Quality (IQ) to fix a Color Night Vision bug
  • Fixed Motion-activated Light bugs
2.1.999 (August 30, 2023)
  • Added Pet to Motion-activated Light Conditions (Wyze app 2.44 or later required)
  • Optimized connectivity quality and speed
  • Updated Image Quality (IQ) to improve low-light performance when using infrared (IR)
  • Improved the motion detection algorithm to reduce false alarms
  • Fixed live streaming bugs
  • Bug fixes
2.0.944 (July 26, 2023)
  • Updated IQ (Image Quality) to improve low-light performance for color night vision
  • Modified the Detection Zone default setting so none of the screen is selected when it is first turned on (factory reset required until the public release of the 2.44 app)
  • Improved motion detection logic inside the Detection Zone
  • Optimized microSD card status reporting
  • Resolved the lingering green box bug
  • Fixed a sunset and sunrise calculation issue
  • Bug fixes
2.0.921 (May 31, 2023)
  • Updated Image Quality (IQ) to improve image quality in both color and IR night vision
Wyze Cam Floodlight v2 Firmware
4.53.13.7771 (September 10, 2026)
Note: This rollout will be happening slowly over the next few weeks. If you do not have the firmware yet, you will receive it soon. Thanks for your patience!
4.53.11.7154 (July 16, 2026)
  • Performance and reliability improvements.
4.53.11.4745 (October 9, 2025)
  • Fixed a bug that caused the device to have higher event recording sensitivity.
Note: This rollout will be happening slowly over the next few days. If you do not have the firmware yet, you will receive it soon. Thanks for your patience!
4.53.9.4352 (September 4, 2025)
  • Improved event video upload success rate.
4.53.9.3438 (May 22, 2025)
4.53.3.9759 (June 10, 2024)
  • Fixed intermittent device offline issues
  • Fixed an intermittent microSD card playback screen flickering issue
  • Fixed an overly dark auto exposure issue at night
  • Added microSD card failure notification
4.53.2.8995 (February 23, 2024)
  • Fixed a bug that caused missing Smart Detection Event Videos
  • Fixed a bug that caused PIR sensors to fail detection
Wyze Cam Floodlight Firmware
1.0.0.55 (December 1, 2021)
  • UI improvements
  • Bug fixes
Wyze Cam v3 Garage Door Controller Firmware
0.10.0.21 (May 18, 2022)
0.10.0.15 (May 5, 2022)
  • Changed the controller trigger duration from 0.2 seconds to 2 seconds
  • Fixed the unresponsive garage door control bug
  • Fixed an issue that prevented QR code calibration due to door closure failure
Wyze Cam v3 Spotlight Firmware
0.0.0.16 (November 22, 2021)
  • Improved the connectivity between the camera and spotlight
  • Added auto-reconnect if connection fails
Wyze Cam Lamp Socket Firmware
0.9.0.29 (June 12, 2023)
  • Fixed the USB protection rule to improve connectivity
  • Fixed a bug that prevented Wyze Cam v3 from recognizing Wyze Lamp Socket after a firmware update or reboot
0.9.0.27 (August 29, 2022)
  • Improved lamp socket reliability
Wyze Cam v2 Firmware
4.9.9.3006 (January 16, 2024)
  • Security improvements
4.9.9.2847 (November 6, 2023)
4.9.9.2351 (September 14, 2023)
4.9.9.1851 (February 2, 2023)
4.9.9.1574 (December 7, 2022)
4.9.9.1472 (November 2, 2022)
4.9.9.1433 (September 27, 2022)
  • Bug fixes
4.9.8.1002 (March 17, 2022)
4.9.8.860 (January 26, 2022)
  • Bug fixes
4.9.8.746 (December 20, 2021)
  • Other bug fixes
4.9.8.501 (November 10, 2021)
  • Bug fixes
4.9.7.1068 (September 8, 2021)
  • Bug fixes
4.9.7.798 (July 21, 2021)
4.9.6.241 (March 9, 2021)
  • Other bug fixes and improvements/span
4.9.6.218 (November 18, 2020)
4.9.6.199 (October 21, 2020)
4.9.6.193 (October 5, 2020)
  • Fixed a bug that caused Wyze Cams to go offline if the camera time zone is outside of GMT-8 to GMT+8
4.9.6.191 (September 30, 2020)
  • Other bug fixes
Note: This update was stopped and we will not be uploading the file for download due to a time zone bug fixed in 4.9.6.193.
4.9.6.156 (July 28, 2020)
  • Other bug fixes
4.9.5.115 (August 31, 2020)
  • Adds the same functionality as the 4.9.5.111 firmware
  • Adds hardware compatibility between Wyze Cam batches
Note: This version was added to give customers an option for flashing back firmware to a previous version. Older firmware versions are being removed from this page because they are incompatible with newer Wyze Cams and would break a newer camera if applied.
4.9.5.111 (March 18, 2020)
4.9.5.98 (January 27, 2020)
  • Other bug fixes
4.9.5.94 (January 21, 2020)
  • Other bug fixes
Note: The .94 firmware version was pulled before most people upgraded to it due to errors that surfaced with the release.
4.9.5.36 (November 15, 2019)
  • Added support for Complete Motion Capture, an add-on service that will record to the cloud whenever there is motion. Free trial available after the upcoming 2.6 app update.
  • Fixed an issue that prevented motion detection, notifications, and local recording in some Wyze Cam v2s.
  • Bug fixes
4.9.4.169 (September 24, 2019)
  • Added new AI model improving person detection
4.9.4.108 (July 8, 2019)
4.9.4.37 (April 22, 2019)
  • Security updates
4.9.4.28 (February 27, 2019)
  • Fixed an issue leading to poor network connections causing device reboots
  • Fixed an issue that may cause time lapse video download errors to occur
  • Security updates
4.9.3.64 (December 17, 2018)
4.9.2.52 (October 22, 2018)
  • Fixed a bug making Playback play faster during the minute transition
  • Other bug fixes
4.9.2.42 (September 17, 2018)
  • Added v1.5 feature support
  • Fixed a bug that when the camera is off, night vision still switches on/off and IR lights stay on
  • Fixed a bug that when the camera is off, it still sends alerts
  • Other bug fixes
4.9.2.18 (July 11, 2018)
  • Added v1.4 app IoT feature support
  • Bug fixes
4.9.1.76 (June 20, 2018)
  • Updated night vision switch logic to reduce frequent switches
  • Updated connection logic to reduce ‘stuck at 3/3’ issues
  • Changed SD card rollover logic to delete 1 hour of oldest video each time
  • Changed an issue that one minute long video only has 52 seconds of audio
  • Changed an issue that with night vision on, recorded video played like in “fast-forward” mode
4.9.1.60 (Apr 25, 2018)
  • Updated IQ to remove the green/lime tint
  • Added noise reduction for background sound
4.9.1.42 (Apr 13, 2018)
  • Image quality (IQ) update
4.9.1.34 (Apr 3, 2018)
  • New image quality (IQ) update
Wyze Cam v1 Firmware
3.9.4.35 (August 17, 2022)
  • Fixed a bug that could prevent the camera from reconnecting
  • This firmware is difficult for the camera to apply due to its size. If your device has a solid yellow light or cannot connect after the update, please try flashing the firmware using a microSD card to recover it
Note: While this product isn't officially supported and we aren't able to fit more features and bug fixes onto the hardware, we’ve created firmware update 3.9.4.35 to fix this cloud connection problem.
3.9.4.32 (January 21, 2020)
  • Other bug fixes
3.9.4.16 (April 23, 2019)
  • Added thumbnails for Event videos
  • Fixed an issue that may cause cameras with microSD cards to reboot
  • Security updates/span
3.9.3.96 (Feb 20, 2019)
  • Additional security updates
3.9.3.88 (Dec 13, 2018)
  • Updated solution for the 'incorrect offline status' issue
  • Fixed an issue that camera keeps some large size videos on SD card
3.9.3.72 (Sept 25, 2018)
  • Added automation and shortcuts, double tap zoom, and arrows in Playback
  • Fixed a bug that with the camera turned off, night vision still switches on or off and IR's stay on
  • Fixed a bug when the alert schedule jumps to a random time schedule after switching to all day
3.9.3.62 (Apr 26, 2018)
  • Motion detection zone (only works with app v1.3 to be released later)/span
  • Allowed turning on/off sound for recording (only works with app v1.3 to be released later)
  • Changed motion/sound alert sensitivity to 1-100 scale (only works with app v1.3 to be released later)
  • Updated connection libraries with better connection results
3.9.2.30 (Feb 15, 2018)
  • Simplified alert logic for better alert and notification stability
  • Enable recording and pause/resume in playback
  • Enable microSD card format
  • Provide option to turn on/off timestamp watermark in video frame
  • Bug fixes
3.9.1.102
  • Improved connectivity focusing on reducing intermittent disconnections
  • Improved troubleshooting during setup
  • Fixed an issue that assigned different MAC addresses for a device
  • Bug fixes
3.9.1.84
  • Alert schedule support (v1.1.42 app or above required)
  • Allowed camera to sync time with the app (fixed DST time change issue, V1.1.42 app or above required)
  • Added troubleshooting during setup for wrong network name and WEP network
  • Tuned down motion alert sensitivity
  • More accurate playback availability display (v1.1.42 app or above required)
  • Updated time verification mechanism
  • Bug fixes
3.9.1.52
  • Improved live stream stability
  • Fixed an issue with no alerts being received when the alert setting is on
  • Fixed an issue with local recording under ‘Record only mode’
  • Fixed an issue with occasional mismatch between MAC address and device ID
Power and Lighting
Wyze Bulb Color (2023 Version) Firmware
1.0.2.60 (March 5, 2026)
  • Improved the responsiveness of the bulbs.
1.0.2.56 (April 30, 2025)
  • Fixed a bug that caused an update failure
1.0.2.51 (November 6, 2024)
  • Bug fixes
1.0.2.14 (May 7, 2024)
  • Added Support for G2 root certification
  • Fixed bug that kept Music Mode from being turned off
  • Fixed issue of low brightness of green light
1.0.2.6 (May 18, 2023)
  • Initial firmware after manufacturing
Wyze Bulb Color Firmware
1.2.0.509 (May 7, 2024)
  • Added support for G2 root certification
1.2.0.508 (October 31, 2022)
  • Improved the color algorithm
1.2.0.435 (June 6, 2022)
  • Extended the timeout when downloading firmware
Update 6/13/22: The issue with this firmware has been resolved. We are now releasing the firmware again.
Note: This firmware has been halted while we look into why some updates have been failing.
1.2.0.429 (February 21, 2022)
  • Fixed a Sun Match bug
  • Fixed a Sleep Routines bug
  • Fixed Music Mode bugs
1.2.0.415 (October 18, 2021)
  • Added support for a timer
  • Added support for Sun Match
  • Added support for grouping with Wyze Light Strip and Wyze Light Strip Pro
1.2.0.339 (May 5, 2021)
  • Fixed a bug that caused setup issues
  • Other bug fixes
1.2.0.333 (March 16, 2021)
  • Added compatibility with CFH (Certified For Humans) bulbs
  • Fixed an issue that caused system crashes during BLE setup
Wyze Bulb Color BR30 Firmware
1.0.1.56 (April 30, 2025)
1.0.1.51 (November 6, 2024)
  • Bug fixes
1.0.1.44 (May 30, 2024)
  • Fixed a bug that kept Music Mode from being turned off
  • Fixed an issue of low brightness of green light
1.0.1.42 (March 4, 2024)
  • Fixed an error that caused cloud processing failures
1.0.1.38 (May 15, 2023)
  • Fixed an output issue that happened for certain cases
1.0.1.32 (November 22, 2022)
  • Bug Fixes
Wyze Bulb White Firmware
1.3.2.29 (June 15, 2022)
  • Added support for a blinking light Rule
1.3.2.27 (February 9, 2022)
1.3.2.25 (December 20, 2021)
  • Fixed a bug that prevented Scenes from applying correctly
Wyze Bulb v1 Firmware
1.2.0.384 (March 4, 2024)
  • Updated a certificate
1.2.0.382 (June 15, 2022)
  • Fixed a Sleep Routine bug that caused incorrect color temperature to display
1.2.0.378 (January 19, 2022)
  • Improved Sun Match
1.2.0.273 (July 29, 2020)
  • Added support for Sleep Routines
  • Added a Reconnect button for if Wyze Bulb goes offline
  • Improved logs
1.2.0.183 (January 21, 2020)
  • Added support for power loss recovery options
1.2.0.173 (January 6, 2020)
  • Modified Wyze Bulb power behavior to reduce the likelihood of a reset due to a power outage
  • Modified what logs collect for improved troubleshooting
  • Multiple bug fixes for connectivity issues
1.2.0.146 (October 2, 2019)
  • Updated maximum length of SSID used for setup from 25 characters to 31 characters
1.2.0.126
  • Fixed an issue causing the bulb’s WiFi adapter to be restricted to the g-band
Wyze Light Strip Pro Firmware
1.2.1.177 (June 10, 2024)
  • Fixed a bug that kept Vacation Mode from working
1.1.1.171 (March 4, 2024)
1.1.1.165 (September 21, 2022)
  • Added support for effects outside of Music Mode
Note: This requires the upcoming 2.35 app to function correctly.
1.1.1.157 (June 28, 2022)
1.1.1.143 (April 18, 2022)
  • Updated implementation for timer, vacation mode, sleep routines, Sun Match, and Rules
  • Improved Music Mode performance
  • Improved color calibration
  • Bug fixes
1.1.1.127 (February 14, 2022)
  • Modified the color temperature range of Sun Match to be the same as Wyze Bulb
  • Improved color accuracy
1.1.1.115 (October 18, 2021)
  • Improved Sun Match behavior
  • Improved Music Mode behavior
  • Fixed a bug that prevented sleep routines from running as scheduled
  • Bug fixes
Wyze Light Strip Firmware
1.2.1.176 (June 10, 2024)
1.1.1.170 (March 4, 2024)
1.1.1.164 (September 21, 2022)
1.1.1.156 (June 28, 2022)
1.1.1.142 (April 18, 2022)
  • Updated offline reporting logic
1.1.1.126 (February 14, 2022)
1.1.1.114 (October 18, 2021)
  • Bug fixes
Wyze Switch Firmware
1.2.28 (March 4, 2024)
1.2.25 (March 22, 2023)
  • Improved the firmware update mechanism to reduce update failures
1.2.24 (January 22, 2023)
  • Improved overall device connectivity
  • Fixed the auto-reconnect mechanism when the switch is power cycled due to power or connectivity
1.2.23 (November 9, 2022)
  • Added support for Schedules in Canada
  • Improved device performance and connectivity
1.2.22 (May 11, 2022)
  • Improved automatic reconnection to Wi-Fi networks
  • Improved connectivity performance
  • Fixed time zone issues for Schedules
1.2.21 (January 19, 2022)
  • Improved connectivity performance so that Wyze Switch reconnects faster if signal drops
  • Feedback is sent to our team if the switch loses connection and gets stuck so our team can investigate which part of the connectivity failed
  • Improved Schedules
1.2.20 (January 5, 2022)
  • Adjusted Vacation Mode intervals to align more with our other products
  • Improved Schedule trigger accuracy
  • Improved Daylight Savings Time (DST) logic for Schedules<></>
  • Improved input validation and responsiveness
Wyze Plug Outdoor Firmware
1.2.0.336 (March 4, 2024)
1.2.0.333 (January 3, 2023)
  • Improved sunrise/sunset execution for Schedules
  • Fixed auto-reconnection bugs
1.2.0.329 (November 7, 2022)
  • Fixed a Schedules bug that caused schedule execution inconsistency
  • Fixed a Schedules bug so now all time zones and all days of the week are supported
1.2.0.309 (September 12, 2022)
  • Fixed multiple issues that resulted in firmware update failure
1.2.0.299 (July 5, 2022)
  • Optimized memory to increase network stability
  • Improved overall connectivity performance/span
1.2.0.293 (April 25, 2022)
  • Fixed connectivity and offline issues
1.2.0.273 (February 7, 2022)
  • Added support for optional automatic updates
1.2.0.219 (January 3, 2022)
  • Improved syncing behavior when Wyze Plug Outdoor reconnects
1.2.0.216 (October 11, 2021)
  • Added a pop-up message when the connected WiFi strength is low to help users find a suitable location for their device
  • Added a status message during firmware update
Note: This is an improved firmware that makes the changes from 1.2.0.206 but fixes a stability issue that we found in that version.
1.2.0.206 (August 30, 2021)
Note: This firmware is halted while we look into a potential issue with it. If you have had trouble with your Wyze Plug Outdoor after updating the firmware, please reach out to Wyze Customer Support.
1.2.0.113 (July 7, 2021)
  • Added the ability to use Certified for Humans and Bluetooth pairing at the same time after the device is reset
1.2.0.93 (April 14, 2021)
  • Fixed a group control bug
  • Fixed a sunrise and sunset scheduling bug
1.2.0.83 (March 3, 2021)
  • Fixed energy monitoring bugs
1.2.0.73 (January 27, 2021)
  • Fixed schedule bugs
Wyze Plug (2022 Version) Firmware
1.2.0.236 (November 29, 2022)
  • Improved accuracy for Schedules
  • Improved reliability and accuracy of high temperature warning for indoor plugs
  • Fixed a bug that caused schedules to execute 1 day from when they’re set
1.2.0.199 (August 10, 2022)
Wyze Plug (2021 Version) Firmware
1.2.0.239 (March 4, 2024)
1.2.0.233 (January 3, 2023)
  • Fixed a bug that caused schedules to execute 1 day from when they're set
1.2.0.206 (May 11, 2022)
  • Improved network stability issues and overall connectivity performance
  • Fixed a bug that caused Wyze Plug (2021) to go offline regularly
1.2.0.179 (February 28, 2022)
  • Fixed a bug that caused frequent connectivity issues
Note: Wyze Plug firmware 1.2.0.179 is being halted as we look into reports of connectivity not being improved by this update and plugs that stop responding after updating. Some regain function a day or two later but others are still unresponsive. If this has happened to you, please reach out to Wyze Customer Support.
1.2.0.176 (January 19, 2022)
  • Added Bluetooth firmware logs if the plug has trouble with setup
Note: This firmware is being halted due to an identified issue that causes the plug to go offline often. We have identified the root cause and are working on a firmware release that will fix the problem.
1.2.0.126 (December 6, 2021)
  • Added support for Time of Day local scheduling
1.2.0.93 (February 24, 2021)
  • Improved plug performance
1.2.0.76 (January 18, 2021)
  • Fixed a bug that caused the status light to remain on
Original Wyze Plug Firmware
1.2.0.80 (August 4, 2020)
  • Improved device connectivity
  • Improved the device log
  • Bug fixes
1.2.0.72 (March 4, 2020)
  • Improved logs for more accurate troubleshooting data
  • Bug fixes
1.2.0.56
  • Fixed an issue preventing connecting to a network that has an SSID with more than 24 characters
Wyze Floor Lamp Firmware
0.1.10 (May 10, 2021)
  • Bug Fixes
Wyze Floor Lamp Remote Firmware
0.0.19 (May 10, 2021)
  • Bug Fixes
Home
Wyze Mesh Router Pro Firmware
1.0.1.167 (June 18, 2025)
  • Bug fixes
1.0.1.121 (May 7, 2024)
  • Enhanced local MQTT PSK security
  • Added support for G2 server certificate
  • Updated local HTTPs certificate for wyzerouter.com
1.0.1.109 (May 1, 2023)
  • Added support for NAT loopback
  • Updated local UI SSL certificate
  • Fixed a bug that prevented the root router from obtaining IP from an ISP modem if the router boots up before the modem
  • Fixed a bug that prevented IPv6 from working properly
  • Fixed a bug that prevented parental controls from taking effect when an uppercase character was configured in the domain
  • Fixed a bug that prevented client devices from obtaining IP when connected to a guest SSID for a satellite router with Ethernet backhaul
Wyze Mesh Router Firmware
1.0.1.166 (June 18, 2025)
  • Bug fixes
1.0.1.120 (May 7, 2024)
1.0.1.108 (May 1, 2023)
  • AAdded support for NAT loopback
1.0.0.74 (January 18, 2023)
  • Fixed a bug that prevented the root router from obtaining IP from certain ISP modems after bootup/reboot with an Ethernet cable connected to the modem
  • Fixed a bug that caused BLE binding to fail when WAN IP is obtained but the system time isn’t synced with NTP
1.0.0.63 (November 15, 2022)
  • Changed the client list reporting interval. Online report will be in 5 minutes and other changes will be reported in 10 minutes.
  • Fixed a bug that caused duplicate MACs in the client list when the backhaul is wired
  • Fixed a bug that prevented the Internet Connectivity LED from working after running for a long time
Wyze Air Purifier Firmware
1.0.18.0 (April 15, 2024)
  • Fixed an AQI reporting issue
  • Fixed an issue that caused a binding failure
1.0.13.2 (January 3, 2023)
  • Fixed a bug that incorrectly reported maximum AQI
1.0.10 (September 12, 2022)
  • Added support for Bluetooth log collection instead of requiring Wi-Fi connection
1.0.9 (August 4, 2022)
  • Improved Wi-Fi stability
  • Fixed a bug that prevented the available Wi-Fi network list from showing during setup
1.0.6 (July 5, 2022)
  • Improved Wi-Fi connectivity
Note: This firmware is halted because of an issue with the upload. We're sorry and are working on a new version.
1.0.3 (April 11, 2022)
  • Adjusted the formula for AQI and PM2.5 conversion
  • Added the ability to select automatic updates
  • Improved default filter life calculation
  • Fixed a location sharing bug that impacted outdoor air quality data and caused repeated prompts
  • Fixed a pollen data update bug that caused repeated prompts
  • Fixed a Wi-Fi icon bug after factory reset
Wyze Thermostat Firmware
1.2.8 (March 4, 2024)
1.2.7 (May 4, 2023)
  • Fixed a reboot issue that occurred after the thermostat was disconnected from Wi-Fi
  • Fixed a sensor bug that occurred when Motion-sensing Comfort was turned off
1.2.5 (October 26, 2022)
  • Fixed an issue causing firmware updates to fail
  • Bug fixes
Note: This is a targeted release to those users that updated to 1.2.4.a2.
1.2.4.a2 (October 19, 2022)
  • Bug fixes
Note: We found an issue with how this firmware interacts with the cloud and have halted it. We're working on an improved version now and appreciate your patience.
1.2.1 (May 4, 2022)
  • Improved processor sync performance
  • Improved Wi-Fi offline reporting performance
  • Fixed a bug that may cause a disconnection after updating firmware
1.2.0 (February 21, 2022)
  • Added a restart function in the app to improve the troubleshooting experience
  • Added a new temperature calibration equation for better accuracy
  • Added the ability to use weather data to determine the heating stage (app and cloud changes need to happen before this is functional but the firmware part is ready)
  • Improved connectivity/span
  • Improved the Fan Activation Delay mechanism so the fan will start to run after the furnace starts with a 15-minute delay when the control board has no internal logic
  • Improved the synchronization between the app and the thermostat
  • Fixed a fan issue for heat pump systems
1.1.8 (July 14, 2021)
Note: Requires 2.22 app version.
  • Increased the report frequency for better stability
  • Fixed a filter reminder bug that caused it to show 0 after an update
  • Fixed an auto-switch bug that would incorrectly activate the motion sensor
1.1.7 (May 12, 2021)
  • Adjusted the temperature correction formula to improve accuracy
  • Heating stage difference is reduced from 5F to 4F
  • Fan activation delay is improved
  • Coast to Cool is 30 seconds now
  • Added a new Fan Cycle setting that matches the app
  • Removed Fan Cycle from the device user interface
  • UI improvements
  • Fixed a bug that caused the thermostat to show as offline when unplugged and reattached
Note: Requires 2.20 app version.
1.1.6 (March 29, 2021)
  • Improved control logic
Note: This rollout is slower than some of our other firmware releases. If you do not have the firmware yet, you will receive it later. Thanks for your patience!
1.1.2 (March 10, 2021)
  • Changed to a new filter reset mechanism to fix an Android issue preventing filter resets
  • Improved calculations for users traveling across time zones
  • Added a 15 second delay between fan and heating to prevent cold air from blowing before the furnace warms
  • Added a differential temperature feature to give more control of temperature accuracy to balance savings and comfort
Walmart Wyze Robot Vacuum Firmware
1.6.313 (November 21, 2024)
  • Certificate update
1.6.306 (December 1, 2022)
  • Added support for Multi-floor Mapping
  • Added support for Spot Cleaning
  • Added support for a Do Not Disturb setting to turn off voice prompts
  • Added a multi-point relocation algorithm. After starting, the vacuum positioning time will be slightly longer to improve navigation performance
  • Bug fixes
Note: This firmware is already present on many Wyze Robot Vacuums purchased from Walmart. This is why it has release notes already listed below.
1.6.202 (March 1, 2023)
  • Bug fixes
Note: This is a 2-part firmware update and is only available for vacuums using 1.6.199. Vacuums running 1.6.306 already have the changes in 1.6.199 and 1.6.202.
1.6.199 (March 1, 2023)
  • Added a multi-point relocation algorithm. After starting, the vacuum positioning time will be slightly longer to improve navigation performance.
  • Fixed firmware update bugs
  • Bug fixes
Note: This 2-part firmware update is only available to vacuums using version 1.6.113. Some vacuums purchased from Walmart already have version 1.6.306. Beta testers using old test firmware ending in .126, .130, or .173 will receive more information about the update process soon and will not be able to update to this firmware yet.&
Original Wyze Robot Vacuum Firmware
1.6.213 (November 21, 2024)
1.6.202 (March 22, 2022)
  • Bug fixes
Note: This firmware will only be available for vacuums using the 1.6.199 firmware version. This will be a double update where the 1.6.199 version is installed before the vacuum updates to 1.6.202.
1.6.199 (March 22, 2022)
  • Improved the navigation algorithm
  • Fixed audio prompt bugs
Note: This firmware will start as only available to a portion of people currently using firmware 1.6.113. The rest of eligible vacuums will be given access to the firmware update later. People using a different beta firmware version will be merged at a later time and will receive more information about the process then.
1.6.113 (April 19, 2021)
  • Added indicators when connecting to WiFi and updating firmware
  • Optimized the mapping algorithm (use the Reset Map/Quick Mapping function to enable this)
  • Optimized WiFi reconnection
1.6.97 (January 18, 2021)
  • Added support for room editing
  • Matched a server-side authentication update
  • Updated the device time sync implementation
Note: If you have a Wyze Robot Vacuum, please update as soon as you can to prevent service interruption.
1.6.75 (December 17, 2020)
  • Added support for designated Area cleaning
  • Optimized the map algorithm
  • Optimized virtual wall setting
  • Adjusted voice prompt
Wyze Sprinkler Controller Firmware
1.0.11 (May 16, 2024)
1.0.10 (July 26, 2022)
  • Further improved a bug fix that addresses Schedules not running for some devices
1.0.8 (April 20, 2022)
  • Fixed a bug that caused Quick Run and Schedules to stop watering shortly after starting
1.0.7 (March 10, 2022)
  • Fixed a bug that caused watering to stop shortly after starting
Note: This firmware is halted because it appears to have not fixed the watering issue. We are continuing to investigate this problem.
1.0.4 (May 19, 2021)
  • Added support for an emergency stop function if a zone has been running for more than 3 hours
1.0.3 (April 21, 2021)
  • Fixed a bug that interfered with physical button function
1.0.2 (April 14, 2021)
  • Added support for emergency water shutoff
Wyze Gun Safe Firmware
1.0.5.0 (March 15, 2022)
  • Factory firmware
Wyze Palm Lock Firmware
1.2.6 (June 16, 2026)
  • Bug fixes
1.2.4 (March 2, 2026)
  • Fixed the issue that some Wyze Palm Lock devices may randomly fail to recognize palms.
  • Fixed the issue that some Wyze Palm Lock devices may randomly fail to wake up.
  • Improved battery performance.
1.2.2 (February 6, 2026)
  • Improved battery management mode performance.
  • Improved gyroscope performance to avoid calibration issues.
  • Bug fixes.
1.2.0 (December 17, 2025)
  • Improved battery management with screen doors. If you were having issues with the battery draining quickly, please make sure the battery management mode is on Auto after the upgrade.
  • Bug fixes
1.1.6 (October 13, 2025)
  • Improved Wi-Fi Connectivity
  • Bug fixes
Wyze Lock Bolt v2 Firmware
1.1.6 (July 6, 2026)
  • Wi-Fi Connectivity Improvement
  • Bug fixes.
1.0.8 (March 2, 2026)
  • Fixed an issue where the battery was draining rapidly under random conditions.
  • Fixed an issue that caused the lock to fail to wake up.
  • Improved connectivity.
  • Bug fixes.
Wyze Lock Bolt Firmware
1.0.6.2 (March 1, 2023)
  • Added support for locking or unlocking Wyze Lock Bolt from the Wyze Video Doorbell Pro live stream
  • Removed the manual trigger required after resuming auto-lock hours
Wyze Lock Firmware
Wyze Lock Firmware
2.1.22.0 (August 4, 2020)
  • Fixed a frequent calibration loss bug
  • Fixed a Works With Alexa compatibility bug
  • Added support for Trash Mode
  • Improved the Wyze Lock calibration process
  • Added a 24 hour open door status alarm
  • Changed the Bluetooth broadcast name
Note: This is being rolled out gradually to Wyze Lock users. If you do not see this update today, you should receive it in the next week.
Lifestyle
Wyze Scale Bodyscan Firmware
1.0.4 (July 8, 2026)
  • Fixed a bug that caused incorrect unit values to display on screen.
Wyze Scale Ultra Firmware
1.1.8 (April 9, 2025)
  • Added logging functionality
  • Added Bluetooth® OTA update capability
  • Adjusted Bluetooth® wake-up function
  • Modified body composition display settings on the scale (Fat percentage and muscle mass are now optional but maintain their order)
  • Updated Wi-Fi firmware SDK
  • Fixed an issue where the fat percentage difference was incorrect when displayed as a separate page
  • Fixed an occasional reset issue
  • Adjusted Bluetooth® speed from 2M to 1M to improve anti-interference performance
  • Changed connection latency from 0 to 2 to enhance interference resistance (OTA update time increased by approximately 1-2 minutes)
  • Adjusted Wi-Fi firmware MSS to improve Wi-Fi OTA success rate
Wyze Scale S Firmware
1.0.107 (April 6, 2022)
  • Changed error code C to error code CAL
  • Resolved Bluetooth connection conflicts between Wyze Scale, Wyze Watch, and Wyze Band for Pixel 6 and Pixel 6 Pro
  • Fixed a bug that caused false Bluetooth connections between the scale and phone and led to high battery consumption
1.0.105 (October 26, 2021)
  • Increased the memory from 24 to 40 slots to save more measurements with the app closed
1.0.104 (September 15, 2021)
  • Fixed a bug that restored incorrect history data
Wyze Scale X Firmware
1.0.109 (June 6, 2022)
  • Improved measurement reliability
Wyze Scale Firmware
Wyze Scale Firmware
1.1.4 (September 10, 2020)
  • Improved the algorithm
  • Bug fixes
Note: This is a gradual roll out. If you do not see the firmware today, you should see it within the next two months.
1.1.3 (August 11, 2020)
  • Bug fixes
1.1.2 (July 8, 2020)
  • Extended the age range for body composition analysis to 100
1.1.1 (May 15, 2020)
  • Improved the data connection reliability
  • Optimized the algorithm
  • Bug fixes
Wyze Watch 47mm Firmware
0.12.49 (July 7, 2021)
  • Turned off continuous heart rate measurement by default
  • Optimized ANC connection
  • Solved the abnormal connection problem from version 0.12.48 that caused issues such as watch face syncing failure
0.12.43 (May 12, 2021)
  • Updated the Raise to Wake algorithm
  • Now automatic heart rate detection will no longer occur during charging
  • Extended the limits for heart rate measurement
0.12.41 (April 28, 2021)
  • When pairing the watch for the first time, the cycle tracker is hidden or presented according to body type selection
  • Added support for rearranging applications on the watch and toggling whether the cycle tracker is visible (upcoming 2.20 app version required)
  • By default, the option for heart rate measurements every 5 minutes is turned on
  • Improved the vibration strength of message notifications
  • Improved the data syncing for the heart rate on the dial
  • The screen will turn off automatically in 7 seconds when using the timer
  • Improved the algorithm for calorie calculation when exercising
  • Fixed a bug displaying incorrect iOS message list status
0.12.37 (March 25, 2021)
  • Fixed a bug that prevented Find My Phone from working during updating
  • Optimized weather data
  • Hid the cycle tracker app for people choosing a masculine body type during setup
Wyze Watch 44mm Firmware
0.3.97 (September 15, 2021)
  • Added support for App Management to allow toggling cycle tracking visibility and changing the app order
  • Improved step counting accuracy
  • Improved the raise-to-wake algorithm
0.3.91 (June 23, 2021)
  • Added app management (Wyze app 2.21 required)
  • Fixed a Cycle Tracking UI error
  • Optimized Cycle Tracking logic
  • Optimized iOS connectivity stability
  • Improved watch software stability
0.3.90 (June 2, 2021)
  • The screen will now light up when receiving a notification
  • Added automatic repair for core data missing error
  • Optimized offline Weather data display logic
  • Optimized connection stability
  • Fixed a bug that caused Weather data to show 0
  • Fixed a restart bug
  • Fixed a bug preventing iOS notification pushes
  • Fixed an abnormal step counting bug
  • Fixed a bug preventing sleep data
  • Fixed Raise to Wake failure bug
  • Fixed a core data missing bug
0.3.68 (April 28, 2021)
  • Fixed a bug that caused the Wyze logo to display for too long after an update
  • Fixed a bug that caused the watch to reboot
Note: This update is halted as we investigate the cause of update failures for some watches.
0.3.65 (April 12, 2021)
  • Optimized system connection stability
  • Optimized Do Not Disturb mode logic
  • Optimized the red dot reminder UI
  • Fixed a disconnection issue
  • Fixed a bug causing the device to reboot
  • Fixed a bug that prevented notifications
  • Fixed a UI bug from when the watch was charging
  • Fixed a bug that caused the watch to restart during heart rate detection
Wyze Band Firmware
Wyze Band Firmware
1.0.8.30 (October 13, 2020)
  • Improved algorithm accuracy for sleep tracking and raise-to-wake
  • Fixed a bug that would cause the charging screen to appear when the band is not charging
  • Fixed a bug that would cause unexpected reboot during a firmware upgrade
  • Fixed a vibration bug with phone call notifications
1.0.7.96 (September 9, 2020)
  • Added a Tool Box function that includes a Stopwatch and Flashlight
  • Added the ability to decline a phone call from Wyze Band
  • Optimized battery level calculation
1.0.7.78 (August 24, 2020)
  • Improved heart rate monitoring accuracy
  • Improved sleep cycle and duration calculations
  • Improved the Notification Box UI
1.0.7.70 (August 10, 2020)
  • Added Google Fit and Apple Health data integration
  • Added a freestyle exercise mode
  • Added support for 12hr/24hr time format change
  • Added support for red dot notifications
  • Added support for changing screen light duration
  • Added a reminder for multiple device logins
1.0.6.96 (June 8, 2020)
  • Fixed a bug causing default alarms to disappear if unpaired
  • Fixed a bug that prevented Wyze Band from becoming fully charged
  • Fixed a Bluetooth connection issue caused by abnormal local Bluetooth binding information for some devices
  • Fixed an issue that could cause Heart Rate data sync failures
  • Fixed a device rebooting issue that occurs when too many notifications are stored
  • Fixed a bug that blocked notifications after phone reboot
  • Fixed a bug leading to frozen step counts
  • Optimized the Weather UI
  • Improved unlocking performance and touch screen responsiveness
  • Improved the Bluetooth re-connection mechanism
1.0.6.78 (May 27, 2020)
  • Improved Alexa response time
  • Improved touch screen performance and response time
  • Improved Alexa error messaging
  • Paused vibrations when speaking to Alexa to improve received sound quality
  • Alexa now resumes the Listening state after recovering from internet or Bluetooth connection error states
  • Holding the Home button in Locked mode no longer unlocks the band or activates Alexa
  • Improved Bluetooth connectivity with Samsung and Google devices
  • Clicking on Shortcuts through Wyze Band now triggers a light vibration response
  • Fixed an issue that caused some alarms to not work when there were multiple alarms set within a short period of time
  • Fixed a bug causing black lines on the screen when exiting Alexa
  • Fixed a bug that could cause a crash when scrolling in the band screen during custom Clock Face image installation
  • Fixed a font error on the Weather page
  • Fixed a battery drain issue
  • Removed redundant iOS Notification logs to optimize Bluetooth connectivity
1.0.6.43 (April 29, 2020)
  • Fixed a bug so that caused holding the Home button to unlock the screen when lock screen mode is enabled
  • Optimized the battery level algorithm
  • Added support for a Sedentary Reminder that will remind people to move around after 50 minutes of inactivity
  • Added support for a daily Step Goal that will track progress on daily step goals
  • Fixed a bug that would cause Find My Phone to not work after the first attempt
  • UI improvements
Note: This is being rolled out to Wyze Band customers gradually. If you do not see the update today, you should receive it in the next week.
1.0.5.80 (April 23, 2020)
  • Improved the Alexa integration
  • Fixed a bug that caused Wyze Band to freeze with a black screen
Wyze Buds Pro Firmware
0.6.6.0 (November 3, 2021)
  • Added a Noise Cancellation Off option for touch control
  • Improved battery measurement accuracy
  • Improved an issue that caused occasional reboots on certain phone models
  • Fixed a bug that caused the right earbud to turn noise cancellation off
0.6.5.2 (August 26, 2021)
  • Added additional case battery percentage syncing to fix a bug that prevented the case battery from displaying
  • Improved Bluetooth connection
  • Sped up the buds startup process
  • Updated the default volume so it is not too loud
  • Improved touch control recognition for triple tapping
  • Fixed a bug that caused the low battery level voice prompt to occur twice
Wyze Buds Firmware
Wyze Buds Firmware
0.0.3.18 (October 25, 2021)
  • Added support for switching between devices by long-tapping both earbuds
Wyze Headphones Firmware
2.1.143 (November 3, 2021)
  • Improved auto-pause
  • Fixed a bug that prevented muting in Zoom meetings on Windows devices
  • Fixed the LED light status when the battery depletes
  • Fixed a bug that caused failure to power on in some cases
2.1.133 (May 19, 2021)
  • Fixed a bug that caused the headphones to reboot during calls
  • Improved the auto-pause algorithm
2.1.126 (March 22, 2021)
  • Added a Noise Cancellation Off mode
  • Optimized call experience and quality
  • Improved auto-pause accuracy
  • Fixed a firmware update bug
  • Fixed an auto power-off bug while the headphones are in a call
2.1.112 (January 5, 2021)
  • Fixed a pairing issue on Android
  • Improved Bluetooth connection performance
  • Fixed a bug that caused noise when inserting a 3.5mm audio cable
2.1.111 (December 14, 2020)
  • Improved the experience of waking up Siri
  • Fixed the audio stuttering issue on Android
  • Fixed an Auto Power Off bug
  • Fixed an issue causing microphone volume to be too low
  • Fixed the disconnection bug with Macbooks
  • Improved the device switching experience
  • Improved the compatibility with iMac
2.1.105 (November 18, 2020)
  • Fixed some random reboot cases
  • Fixed a bug causing noise during voice calls
  • Fixed a bug that sometimes prevented EQ from working
  • Fixed a bug that caused incomplete playing when listening to short audio clips
  • Fixed a bug causing noise when using Alexa
  • Fixed a bug causing lost settings after updating firmware
  • Fixed a battery level bug that occurred after turning off then on the headphones without charging
  • Improved wearing detection
Sensors
Wyze Sense Hub Firmware
4.32.14.716 (April 28, 2025)
  • Improved hub connectivity
4.32.13.685 (July 12, 2023)
  • Resolved an internal metrics bug
4.32.13.673 (June 22, 2023)
  • Improved Wyze Sense Hub’s Wi-Fi connectivity after a power outage
  • Improved the time synchronization mechanism of the hub and fixed Monitoring Events sequencing issues
  • Stability and connectivity enhancements
4.32.12.534 (March 1, 2023)
  • Added support for Additional PINs (2.40 or above app version required)
  • Fixed a bug that prevented the Environment Hazard reminder from being stopped
  • Fixed a bug that turned off Environment Hazard functions
  • Fixed a bug that blocked switching to Wi-Fi after connecting via Ethernet
4.32.11.365 (November 28, 2022)
  • Improved the Environment Hazard Remediation experience
  • Fixed Bluetooth log collection
4.32.10.315 (October 21, 2022)
  • Improved performance
4.32.9.264 (July 7, 2022)
  • Fixed a Wyze Sense Hub bug that caused sensor pairing and connection failures
4.32.9.249 (April 25, 2022)
  • Improved Ethernet network connectivity
  • Enhanced Wyze Sense Hub audio volume
  • Fixed a bug that prevented the Entry Notice from playing when a door was opened
  • Other bug fixes
Note: This firmware does not address the sensor connectivity issue some are experiencing and we're continuing to work on resolving that issue. Thank you for your patience.
4.32.8.246 (April 8, 2022)
4.32.8.213 (March 2, 2022)
  • Improved network connectivity and reporting accuracy
  • Bug fixes
Note: This firmware is halted due to reports of issues such as sensor connectivity problems. If you are experiencing trouble with your Wyze Sense setup after updating, please reach out to Wyze Customer Support.
4.32.7.177 (December 8, 2021)
  • Network reliability and performance improvements
  • Bug fixes
4.32.6.142 (October 18, 2021)
  • Fixed a bug that prevented some users from saving the entry sensor chime sound in Tune Settings
  • Fixed a bug that caused some users to have their entry sound off by default
  • Fixed a bug that caused a decrease in Wyze Sense Hub voice prompt volume from last update
  • Fixed a bug that caused difficulty in switching modes for some users
  • Fixed a bug that caused an operation delay after switching networks for some users
Known Issue: There is a user interface bug that makes it look like hub volume has not been changed to the low or mid settings. Upon re-entering the Hub Settings page, the display will revert back to the previous setting. The actual volume will be changed and saved.
4.32.5.92 (September 22, 2021)
  • Fixed a bug that caused some hubs to turn off immediately after the hub is unplugged from power
4.32.5.80 (September 8, 2021)
  • A PIN is now required to switch to enter Disarm Mode from the keypad
  • Added a fast beep for Entry and Exit Delay
  • Fixed a bug that caused some delayed false alarms for some people
4.32.4.295 (August 4, 2021)
  • Added active sensor activity to Monitoring Events
  • Added a toggle for the entry/exit delay countdown sound
  • Added a chime notification sound when on-duty sensors are triggered upon entry
  • Improved the offline Hub audio notification experience
4.32.3.183 (June 10, 2021)
  • Improved Hub offline performance
  • Optimized sensor function reliability
  • Improved the Hub countdown experience
4.32.2.127 (April 6, 2021)
Wyze Sense Keypad Firmware
0.0.0.63 (April 6, 2021)
  • Initial keypad firmware
Wyze Sense Bridge Firmware
0.0.0.33 (July 8, 2019)
  • Added status light control
  • Removed Bridge reset button functionality
Miscellaneous
Wyze Web Portal
Wyze Web Portal
2.7.4 (July 11, 2024)
  • Minor bug fixes
2.7.1 (June 24, 2024)
  • Added a mechanism to submit a log file to help our team diagnose web connectivity failures on the live view
2.7.0 (June 12, 2024)
  • Added the ability to create multiple payment methods
  • Added the ability to assign a backup payment method in case default payment method fails
2.6.0 (May 24, 2024)
  • Enabled multi-day filtering for recorded events
  • Fixed a bug to allow legacy Cam Plus plans to extend to the next billing date when upgrading to Cam Unlimited
2.5.0 (April 15, 2024)
  • Changes to service upgrades on my.wyze.com
2.4.11 (March 20, 2024)
  • Fixed a bug that caused beta app users not to be able to live stream on my.wyze.com
2.4.7 (February 7, 2024)
  • Optimized the experience for customers with many devices
2.4.6 (January 31, 2024)
  • Updated our secure payment capture form for adding and updating payments used for service plans
2.4.3 (January 25, 2024)
  • Enabled a dynamic resolution in the livestream multi-camera view based on network conditions. Full screen view increases resolution.
2.4.2 (January 11, 2024)
  • Added a reconnect mechanism to automatically reestablish liveview connections for Wyze Battery Cam Pro devices
2.4.0 (December 19, 2023)
  • Added the ability to scrub through the cloud Event timeline in Wyze Web Portal
  • Implemented retry logic to reestablish live stream connectivity with Wyze Cams in Wyze Web Portal
  • Improved the Wyze Web Portal tool for adding subscriptions to Wyze Cams
Wyze Car
Wyze Car Android App
3.0.25 (April 7, 2026)
  • Bug fixes.
3.0.15 (May 16, 2024)
  • Security updates
3.0.14 (March 29, 2024)
  • Fixed an issue preventing users from logging in
3.0.9 (March 27, 2024)
  • Added support for Oauth login
  • Added support for Trusted Devices when using Two-factor Authentication (2FA)
1.1.15 (July 12, 2023)
  • Added support for 2FA
Wyze Car iOS App
Wyze Car iOS App
3.0.8.1 (May 16, 2024)
  • Security updates
3.0.7.5 (March 27, 2024)
1.1.72 (July 12, 2023)
1.1.71.4 (June 1, 2023)
  • Optimized UI for iOS16
  • Fixed the bug that prevented sound on the livestream recording screen in iOS16
1.1.68 (November 15, 2021)
  • Fixed a crash issue that happened when submitting logs for feedback
Wyze Cam v2 Firmware (for Wyze Car)
4.55.0.130 (May 28, 2024)
  • Security Improvements
4.55.0.114 (November 10, 2023)
