Do the headphones work without the Wyze app?
Yes, for the basics.
You do not need to be connected to the Wyze app to use the basic functions of your Wyze Headphones, only a Bluetooth connection.
However, you must have the Wyze app to customize the equalizer, set up your voice assistant, use touch controls, and more. Most advanced settings require the Wyze app.
