Note: You'll need to be on Wyze app version 3.14 or above in order to set up or reconnect your Wyze Solar Cam Pan.
To factory reset Wyze Solar Cam Pan:
- Remove any microSD card that is inserted into the camera.
- With the camera powered on, press and hold the setup button on the top of the camera for 20-30 seconds.
- Once the status light starts flashing red, set up the camera as new.
