My Wyze Solar Cam Pan 2K is drifting.
Note: You'll need to be on Wyze app version 3.14 or above in order to set up or reconnect your Wyze Solar Cam Pan 2K.
Problem
Your Wyze Solar Cam Pan 2K drifts away from the Home Waypoint position, without you updating or controlling it.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Solar Cam Pan 2K’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Disable Track Person.
    1. Under the camera live stream, swipe left/right on the toolbar to find Track Person.
    2. Tap to turn it on/off.
      • The icon will be grey when turned off.
  4. Calibrate the camera.
    1. In the camera’s settings, tap Pan Controls.
    2. Next to Calibrate Position, tap Calibrate.
    3. Wait for the calibration to complete before exiting that screen.
    4. Note: Ensure there is nothing impairing the camera’s ability to move, including the solar panel or its power cable.
  5. Adjust the Waypoints.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Waypoints.
    2. Tap Waypoints to view the existing Waypoints.
    3. Remove any existing Waypoints, and add them back one at a time, testing between each one.
  6. Check if there are any shared users adjusting the camera.
    1. Navigate to the camera’s settings > Sharing.
    2. Temporarily remove shared users, if needed.
  7. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  8. Factory reset Wyze Solar Cam Pan 2K.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 20-30 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
