My Wyze Solar Cam Pan 2K is not detecting pets.
Note: You'll need to be on Wyze app version 3.14 or above in order to set up or reconnect your Wyze Solar Cam Pan 2K.
Problem
Your Wyze Solar Cam Pan 2K is not detecting pets at all, or it is inconsistent.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Solar Cam Pan 2K’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Check that the camera is set to record correctly.
    1. Navigate to the camera’s settings > Event Recording.
    2. Enable Motion, then select All Events.
    3. Next to Recording Preferences, tap Customize.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to have the pet trigger the camera.
    6. Note: For Wyze Services users, once recordings for Other Motion are being generated, you can select the desired AI recording by checking the other options in the Tag and Notify columns.
  4. Adjust the Detection Settings.
    1. Navigate to the camera’s settings > Detection Settings.
    2. Tap Detection Zone and toggle it off while testing.
    3. Under Detection Range, adjust the slider to Far.
    4. Under Motion Sensitivity, adjust the slider to High.
  5. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  6. Factory reset Wyze Solar Cam Pan 2K.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 20-30 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
Note: Wyze Solar Cam Pan 2K uses PIR to detect motion using heat. Due to the nature of PIR technology, the placement of the camera, and the small size of most pets, pet detection is not guaranteed.
