Can I use Wyze Scale UltraBodyScan with wet feet?
Not wet, but damp is fine.
Wet feet may affect the accuracy of your measurement. They also can make the scale slippery and not safe to use. Only step on Wyze Scale Ultra BodyScan with dry, or slightly damp, feet, and when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
