What are the key differences between Wyze Cam v3 Pro and the original?
Wyze Cam v3 Pro looks a lot like a Wyze Cam v3 with a spotlight built-in, but it offers so much more.
Wyze Cam v3 Pro comes with these new features:
  • A brand-new app UI with spotlight controls, a simplified Event view, and Smart Focus.
  • Smart Focus feature zooms in on motion on the Live stream, alongside the bigger picture.
  • 2K resolution so clear, it lets you read what you need to read.
  • Built-in spotlight to not only detect, but deter.
  • Faster detections with Edge AI, which doesn't rely on the cloud.
  • On-board Person Detection, also thanks to a faster processor and Edge AI.
  • An even louder siren at 89db, and overall better audio quality.
  • A stronger Wi-Fi connection with 2 antennas.
Wyze Cam v3 is still a stunner, and comes with:
  • Amazingly clear 1080p resolution lets you see what you need to see.
  • Excellent Color Night Vision with only a tiny bit of light needed.
  • Starlight CMOS Sensor for clear viewing in super low light.
  • Wired capabilities, not wireless or battery-powered (so no need to recharge).
  • IP65 weather resistant, specifically made for indoor and outdoor use.
  • Dual IR Light System, for better indoor infrared lighting.
  • Ability to add accessories, like the Spotlight kit.
