Can I swap out my Wyze Cam v3 with Wyze Cam v3 Pro?
Yes, but swap out the power adapter, too.
While the power cable is the same, the power adapters are different. You will need to use the adapter that comes with the Wyze Cam v3 Pro, not the adapter that came with your original v3. It uses a 5v2A adapter instead of 5v1A.
