Can I use Wyze Cam Pan v3 outdoors?
Yes, it is outdoor-rated!
Wyze Cam Pan v3 is IP65-rated and can be used both indoors and outdoors. Wyze Outdoor Power Adaptor v2 (coming soon!) is required for outdoor use. You'll also need to cover the SD card slot to avoid water damage.
Still need help?
