How do I reset the position of my Wyze Cam Pan v3?
Notice your Wyze Cam Pan v3 rotating a little funny, or not fully entering Privacy Mode (turning fully down)? Chances are, you accidentally bumped it or adjusted it manually, and it needs recalibration.
To recalibrate the position of Wyze Cam Pan v3:
  1. In the Wyze app, tap on your Wyze Cam Pan v3.
  2. Tap the Settings gear > Advanced Settings > Motor Controls > Reset Position > Reset.
When your camera stops moving, the position is reset!
